ran out of money
Water pump question on BBC
I was wondering if a Long Water Pump would work on a BBC with 72 style mounts on our trucks? I figured shorts came with the truck but i was wondering if i would run into clearance problems with a long pump.
Thanks for any input 71rat
Modify everything, leave nothing alone!~ ![]() ![]() |
![]() Join Date: Mar 2003
Re: Water pump question on BBC
electric fans.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Im running a lwp but have yet to get to the cooling part of the equation..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I dont think it will. I have a bbc with a long water pump in my 69 with the tubular motor mounts and I have shifted the engine back 1 in and I barely have enough room for my electric fan.
![]() Join Date: Aug 2004
I re-sold a serpentine belt setup since it put the wp hub too close to the radiator. I would have had to pull the rad to get the pulley off.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
ran out of money
thanks everyone for the input
You will have about 2 3/4" of space between the pully and the rad.
I can't find a electric with less than 2 3/4" depth. I have a 16" flex fan and 2 electric in front pushing. 12" and a 14" fan in front of the air-condenser. In traffic it starts to climb to about 220 degrees. If the outside temp are in the 60's it will stay below 210. I am thinking of maybe side drafting electrics on angles and blow on the inner fenders. The 2 3/4 is the water pump pulley, the air conditioner compressor sticks out further.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne Last edited by dwaite72lnghrn; 11-23-2007 at 06:21 AM. Reason: additions. |
LWP will not work on a big block truck with the mounts in the bbc position.
You shouldn't have any overheating problems with a 4 core and a dual electric fans with a SWP. If you do, something isn't right. I have a 509" with a 4 core $200 radiator in it, and a derale dual electric fan. 180 degrees...period. ![]() hope this helps. Last edited by Ozona; 11-23-2007 at 09:21 AM. |
Living In The Past
Long water pump on BB in stock location does fit on mine. I come up with the same measurment as dwaite72lnghrn. I just went searching for a clutch fan that was the right length and found one that leaves the fan about 3/4 inches clearence from rad. I dont like it that close though and there is a little overheating issues when using ac in slow traffic. I plan on changing to electric fans. You likely wont find an electric fan that would have the clearance to sit in the middle of the rad, but using 2 side by side will work and that is my plan when I get around to it.
PROJECT 7DEUCE
Wes at classic heartbeat has a sweet dual fan set-up that I have been eyeing for this project..
Anyone have any idea what the difference will be in rad clearance between a SWP and LWP? I have a 5600 cfm flexalite dual electric setup that just wont quite clear with my Edelbrock victor series LWP.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
