Old 11-22-2007, 11:35 PM   #1
71chevylowrider
71chevylowrider's Avatar
who can weld this?
I really need some help from a local member that can weld a broken spring in my bench seat, it's the weird "Z" spring that holds up the very end of the foam pad (when you slide out of the truck it keeps the foam from compressing down too far) I want to re-cover the seat, but first I need this spring repaired, anyone here locally that could do it, I will pay $$, or beer, or trade for other parts I have ect.
71chevylowrider is offline   Reply With Quote
Old 11-22-2007, 11:51 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: who can weld this?
I'd be glad to do it for you man, but we are on the opposite side of the rock!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-22-2007, 11:51 PM   #3
Blue_71
Bloo
Blue_71's Avatar
if youd like ill check, i may have one of those springs out of a seat i disassembled. or if you wanna pay mail-tag, i could weld yours
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 11-22-2007, 11:56 PM   #4
71chevylowrider
wow, this is great, you meet the nicest people in Alabama & Kentucky! I was sure hoping one of the locals would be so kind, but I guess beggers can't be choosers, the seat is out of 72, can you look & see if you have the spring? I need the one that goes on the driver's side, there's only one like it on each end of the bench seat, if you have one I'll buy it & pay for shipping, I have another seat, but the same spring is broken & I'm not sure if their bent the exact same way on the passenger side.
Old 11-23-2007, 01:56 AM   #5
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
If you weld it, you will lose the metalurgical property in the spring. It would be much better to get one off an old seat.
Tom Vogel is offline   Reply With Quote
Old 11-23-2007, 03:39 AM   #6
OhioDan
OhioDan's Avatar
If you weld it, you would take the temper out. You'd have to heat the whole spring and take the temper out. Weld it, and then re-temper it. Best to find a new spring.(take it out of another seat?) Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-23-2007, 09:11 AM   #7
68gmsee
Active Member
68gmsee's Avatar
I had the same spring broken on both sides of the seat that I bought used. I believe it's a fairly common weak point.
On mine, I took a spring from an older style bench seat and formed the spring to fit. Ain't the best, but it worked for now.
68gmsee is offline   Reply With Quote
Old 11-23-2007, 10:04 AM   #8
GMT900
GMT900's Avatar
Go to local upholstry shop and buy a new one cheap cut it to length and install. Should be less than 10.00
The puppy barks but the trucks roll along.
GMT900 is offline   Reply With Quote
Old 11-23-2007, 11:40 AM   #9
billdo
billdo's Avatar
it willl probly break again not because of who will weld it but because of the material. its "spring steal" witch doesnt like to be welded
billdo is offline   Reply With Quote
Old 11-23-2007, 12:19 PM   #10
Frizzle Fry
Frizzle Fry's Avatar
I'd do it for ya man, but it sounds like you're better off replacing it.
Frizzle Fry is offline   Reply With Quote
Old 11-23-2007, 01:34 PM   #11
chevy72blu
chevy72blu's Avatar
Huh... learn somethin new every day I guess. I knew there was a metallurgical difference between spring steel and regular steel, and I suppose it makes sense that welding would tamper with the molecular structure of the steel. Interesting stuff
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 11-23-2007, 01:45 PM   #12
Stoney
Farm Truck
Stoney's Avatar
Mine broke were it's welded to the seat frame and I T.I.G. welded it and it hasn't broke yet. But they're saying if it's actually in the spring it will break again. Spring steel doesn't like being put back together.
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 11-23-2007, 02:51 PM   #13
70GMCer
70GMCer's Avatar
Talk to centless on here. He did it. Just go a buy a new one cheap...
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-23-2007, 03:17 PM   #14
60ratrod
yes, i do
60ratrod's Avatar
hey lowride, i can do it for you if you wanna come up to whidbey. my buddy has a welder that i can use. should be a simple fix if you aren't concerend with the whole retempering thing for the time being.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 11-23-2007, 03:35 PM   #15
71chevylowrider
I guess I never thought about the tempering aspect of it, it's just broke into 2 pieces & I thought it could be welded back together, I guess I will look for a new one or make one out of the old seat. Thanks very much everyone for all the advice, I'd hate for the spring to break again after I stretch & hog ring the new $200 cover on it.
Old 11-24-2007, 07:24 PM   #16
billdo
billdo's Avatar
im glad others agree see i kinda know because i am a welder at a local shop and my boss who has probly forgotten more then i know lol tells me you cant weld spring steal it will always break again
Old 11-25-2007, 12:07 AM   #17
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Upholstery shops have the spring wire, they buy it by the roll. Take the bench to them and they will fix it, this really no biggy.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
