Strange headlight problem
I am having some issues on my 86 that is equipped with dual headlights. When I select low beams they work normally but the high beams are on very dim. When I select high beams, the high beams work normally, but the hi elements in the low beam bulb are on dim. Any ideas?
Re: Strange headlight problem
Poor (loose or rusted) ground.
1970 long fleet, 355 4 speed, primer, walnut goodies |
Droppin' It Like It's Hot!
Agreed or a short in the power wires. I was having a problem with mine, the headlights on - right turn signal inop, high beams on - right turn signal inop and right high beam inop. Some of the wires in the loom behind the grille had been rubbed through and shorted together.
Robert
Life Member RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09 1969 ![]() Norwood, MO 2007 Big Sandy, TN 2008 Had nothing to do with the forklift! Kirkwood, MO (Midwest Meet 2009) Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014 SUPPORT THE SITE HERE! |
Gen III Power
Hello..
Did you ever solve this problem...Im having the same problems you described.. My grounds are all decent.... Next step is to re-wire the lights.. ![]() |
