11-23-2007, 04:25 AM | #1 |
Converting a C20 to C10
What is the difference in the spindles of a C20 compared to a C10? I was looking for wheels for my C20 and I couldnt find any I liked in eight lugs so I want to switch to the 5x5. Can I just take the C20 spindle out and put a C10 disc brake kit in? Also will the 5 lug replacement axles from CPP work on my eight lug rear end? Its a 12 bolt with 4.10s but thats all I know. I dont know the spline count.
SSG Jeffery Ahlheim 586th Network Support Company, 525th BfSB US Army, FT Bragg, NC 2009 Chevy Silverado LT ext cab 5.3L If you don't stand behind our troops, please feel free to stand in front of them. |
11-23-2007, 07:46 AM | #2 |
Re: Converting a C20 to C10
Call up Terry at ECE and tell him Kevin from Winters sent you his way. He should be able to help you ihn all your questions and has great parts to do it as well.
Kevin LFD Inc. |
11-23-2007, 02:12 PM | #3 |
A guy with a truck
Up front, you will need to swap out the balljoints and lower a-arms to use the 1/2 ton spindle. Since your truck is a '67, you should have a narrower rear axle than the later model trucks with the 5x5 axles. You can still use these with the larger HD brake drums to take up the space, or the conversion axles should work. All truck 12 bolts are 30 spline.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
