The good/the bad/the ugly....need transmission recommendations
The good: Finished getting the motor in yesterday. Runs like a scalded dog.
The bad: The tranny started slipping after about 10 miles. The ugly: Tranny is shot after 20 miles. This is just my luck. Four months to get this beast built and the tranny goes after 20 miles. 20 miles?!? I didn't even have time to get on it good. ![]() |
Re: The good/the bad/the ugly....need transmission recommendations
I've been building a 454 to make 500 at the crank (numbers wise anyhow) and was told/so I bought, a 400 tranny. I figure picking up a cheap one and then spending 5-800 getting it rebuilt is the way to go. By the time I get to it, it'll probably cost a grand but I at least have the tranny!
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I went with a th400 had it rebuilt by a local shop for more power out handling hopefully it will work..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
You know that brings up another question which I'm sure has been asked a million times: should I stick with the 350 or ?
![]() Join Date: Dec 2006
If you decide to get this one make sure they replace the steels (in the clutch packs).
Personally I'd feel much better with a 400.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 11-23-2007 at 10:59 AM. |
sometimes racing trannies arent very good for drivers and dont last many miles
Anyone ever used RPM tranny's?
Hootis is as Hootis does...
Simple answer - with that much power - T400 is the way to go. Mine was built with all the good stuff - and is good for up to 800 hp - get a good converter and replace the Ujoints while you've got the shaft out and the last piece you'll have to replace is the rear end...
Good Luck
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires 1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires 1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires |
#9 | |
Either tranny can be built to handle your HP/TQ requirements, but the TH400 will have a little more safety factor built in should you decide to spray it later. The TH400 has another advantage, and that's a larger output spline and U-joint that's less likely to fail on you. However, a friend of mine has a TH350 behind a potent 396/402 and it's holding up just fine. I'd say, if you can buy a really beefy TH400 for less than $1000, then go for it. If not, find a good TH400 core for $100 or so and put $600 to $800 of parts in it yourself. Monster and Art Carr are some others who I hear build beefy transmissions but I've never used either.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
