11-23-2007, 12:57 PM | #1 |
Will Chevy Caprice Rims (5x5) Fit?
I have some winter wheels for my 95 Impala SS sitting in the back of my garage and a 69 truck rolling chassis with crappy rims/tire on it and...
My question is will the 9C1 (cop car rims) fit on my truck chassis - both are 5x5 but didn't know if the rim would clear the hub...or if there was a difference in backspacing between car and truck ralleys... Here is what they look like...(borrowed a pic from elsewhere) |
11-23-2007, 01:59 PM | #2 |
Re: Will Chevy Caprice Rims (5x5) Fit?
If they are like the aluminum SS ris they will fit. Friend of mine for giggles put a set of the aluminum SS wheels on 71 2wd and had 0 problems. If there had been he would not have done it- all about the easy.
11-23-2007, 02:27 PM | #3 |
yes they will fit i got a caprice rear end in my 65 . they have chevy truck lug pattern
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
11-23-2007, 02:35 PM | #4 |
I'M TRUCK CRAZY!
yes, they will work just fine. You must have done a 6 to 5 lug conversion?
11-23-2007, 02:37 PM | #5 |
I've got a set on the front of my truck right now.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
11-23-2007, 02:52 PM | #6 |
Nope - but PO did...
And also swapped to a front disc setup as well. This will be my builder frame once I get my solid project to work on... Thanks Everybody - now I got something to do tomorrow after I eat. |
