People know me
Heater!!!!
Ok this is my first winter with my 72 k5, It has a single wall top and is bedlined throughout the interior. My question is do your heaters work well? It was 15degrees this morning and I went out and fired it up 20mins before I left for work. all the windows were still frosted over including the front with 2 dinner plate sized spots that were defrosted. I mean the heater blows out fairly warm air, But maybe i need a new heater core? Supplemental heater? Do you guys have problems with yours?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
Re: Heater!!!!
I put a newer model a/c fan in place of the original. It blows three time the air the old one did.
The LuvShack Garage
Re: Heater!!!!
Seat Heaters, kits available online or ebay, work very well
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#4 | |
People know me
Re: Heater!!!!
Seat heaters arent gonna work with my aftermarket 4point seats
Re: Heater!!!!
Try a hotter thermostat temp for winter driving. This will allow the water temp to go a bit higher, and generated more heat for your heater.
Re: Heater!!!!
My son told me you can put a bigger motor in the fan unit, supposed to be a direct bolt in. '80 to '90 maybe. If I get more info I'll pass it along, I haven't looked into it yet
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
The LuvShack Garage
Re: Heater!!!!
The ones I saw will work on any covered seats, now if they are resin then no.
Future TOTM Winner
Re: Heater!!!!
I wonder if the thermostat is working at all. If it is stuck open (or totally removed) it wouldn't really warm up at all, especially in that weather. After 20 minutes, that thing should be pretty warm!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
![]() Join Date: Jul 2003
The heater in my '70 worked well when I was driving daily in the winter.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
People know me
Re: Heater!!!!
i will replace the t-stat this weekend, It has a 180degree in it now, it works great my temp gauge warms up to 190 then drops to 180 and stays there. i get decent air flow, and I realize its alot of space to heat also, just dosent seem like its working as well as it should be
Re: Heater!!!!
All the above ideas are great, but you may need a new heater core as you stated as well...JAT
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Heater!!!!
I totally rebuilt my whole heat system last year and it still sucks.... I have not however upgraded my motor...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#13 | |
Re: Heater!!!!
![]() The part# for the upgraded fan is pm102. and there may be one with even more cfm's That is a seriously super cool flats racer in your avatar
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-23-2007 at 09:10 PM. |
#14 |
Re: Heater!!!!
Does it need any modifications to install??
#15 |
PROJECT 7DEUCE
Re: Heater!!!!
Thanks for the hook up on the part # ill have to see if I can round on eup..
#16 |
Re: Heater!!!!
Don't really know, just had an informal chat with my son one day while we were talkin truck stuff, and he said "ya know Dad"
I will go back and ask him the low down now. The best place to start would be the junkyard. Ya all have a Happy Thanksgivin'.....J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-23-2007 at 11:09 PM. |
#17 |
![]() Join Date: May 2006
Re: Heater!!!!
Cold weather is one of the reasons I put a half cab on mine. Brrrrrrr.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
#18 |
Re: Heater!!!!
Both my blazers will run you out in the winter heat wise. New heater core does make a huge difference. My 71 was doing that but it was the duct hoses were coming apart. Got new hoses and that was it
#19 |
People know me
Re: Heater!!!!
I have also replaced the heater ducts during the rebuild, the old ones were duct tape!
#20 |
Re: Heater!!!!
You need the engine to make heat, first.
Next make sure your heater core is flowing coolant. Then and only then will you get heat into your interior. Update this thread to, I'm sure knowing the outcome will help all. http://coloradok5.com/forums/showthread.php?t=221219 |
#21 |
Re: Heater!!!!
This is probably a long shot.
Last year mine was doing the same thing, the PO had put a T-valve inline on the heater hose just before the heater core. That valve had rattled itself 90% closed so I was not getting enough coolant to make any heat. |
#22 |
People know me
Re: Heater!!!!
Went and picked up a new heater core and 195 t-stat, After getting the heater core assembly out It had a bunch of leaves and crap stuck in there. Got it all put back together and all I can say now is WOW!!! This thing puts out some serious heat! Very happy with the Results, Thanks for all the input guys!
