Restoration Desperation
Fuseable link, Fuse, Gremlins, or......
Operator error?
Ok, i had the "new" 350 running a couple of weeks ago before vacation. So, today i fixed some minor stuff, charged the battery & hooked up the alternator. I thought the alt had the plug, a jumper from the plug to the post and a separate wire also to the post. Hit the started, and...poof, lost everything. No lights, nothing. The fuse block shows no fuses blown. Is there a fusable link? I tested the battery, it's ok, could it be the ground? WTF? I am electricly challenged, so i am not really sure where to start. All help appreciated....... RD |
Re: Fuseable link, Fuse, Gremlins, or......
There is a fusible link close to the battery in the harness that runs across the radiator support. It is possible that it blew from the sounds of things!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
OK, i'll take a look.........
RD |
