![]() Join Date: Dec 2003
Alternator mounting locations....
ok.. i've got a factory big block factory air truck... 1970... i am pretty sure that the alt is supposed to go on the drivers side.... but i can't find a upper mounting bracket for it... i am using a small block one now with the bolt not even in the slot part but out on the end of the bracket.... was the big block upper bracket the same just longer????? i can't find any info... does anyone have some pics or suggestions...
thanks..
https://www.ebay.com/itm/295742064443 |
Re: Alternator mounting locations....
I'll be keeping an eye on this thread, I have the same dillema.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 |
Ebay? LMC?
no luck on info..... the ones they show look the same as what i have but what i have is too short
67-72 parts collector,…
![]() Join Date: Nov 2002
Can you post some pics of what you have?
CHeck out this thread in the parts section. Here's you answer,...http://67-72chevytrucks.com/vboard/s...d.php?t=267541.
![]() Join Date: Dec 2006
Here's a closeup of the right bracket from my old 72 Custom Camper. Man, I wish I'd kept that truck!!!
#8 | |
Always on the hunt...
![]() Join Date: Sep 2006
![]() Last edited by Classic Bowties; 11-25-2007 at 03:30 PM. Reason: info |
ok, great info that looks just like what i have but mine is too short... the alt hits the valve covers.... does the small block one look just like that one???
heres a pic of what i have.... if i move the alt into the ajdusting slot it hits the cover.
![]() Join Date: Aug 2004
The 68-71 BBC top bracket looks very similar to the SBC one you have, but it's longer.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Franko72
those pics are dead on! I removed all of those parts today to change a leaky mainifold gasket.Easy to remove and replace.There is a strut type bar that mounts from the middle of the drivers side cylinder head to the top of the body bracket for support.
![]() 1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
