Old 11-23-2007, 09:30 PM   #1
pocoloco71
pocoloco71's Avatar
ram horn redo, check it out
I saw an article on this a good while back and grinding on my set while
the motor was at the machine shop. Any way check the one I finished
versus the one to be completed.
pocoloco71 is offline   Reply With Quote
Old 11-23-2007, 09:55 PM   #2
pocoloco71
pocoloco71's Avatar
Re: ram horn redo, check it out
Ok, I posted wrong spot I guess. Should have tried detailing maybe?
Old 11-23-2007, 09:57 PM   #3
Boog
laying low
Boog's Avatar
Hey it looks good. What did you use to smooth it up? I'd like to do mine and paint them a nice gray hi temp paint.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-23-2007, 10:54 PM   #4
pocoloco71
pocoloco71's Avatar
I used a 4 inch makita angle grinder to get all the major bumps off. Then
a dremel tool in the hard to reach areas. Then meadia blasted in some
areas with aluminum oxide. Plus some sanding with 150 grit. I was a lot
of work. But hey you got to pass the winter some how.
Old 11-23-2007, 11:48 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Cool! I had mine done too. Then we thermal coated them...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-24-2007, 08:18 AM   #6
pocoloco71
pocoloco71's Avatar
That is sweet. I did wonder about that. But wasn't sure if those folks would
want to do old stuff. Anyway that looks wonderful.
Old 11-24-2007, 08:36 AM   #7
Boog
laying low
Boog's Avatar
I guess you could call that a Golden Ram! Sure is smooth.
Boog
primer is finer
