Old 11-25-2007, 09:36 AM   #1
AusMarty
Neat comp cam selection program
I found this nice program from competition cams for selecting a cam , gives estimated horsepower and torque, a bit like desktop dyno.
Dunno how accurate it is maybe someone can compare it with desktop and let us know, here's the link
www.competitioncams.com
AusMarty is offline   Reply With Quote
Old 11-25-2007, 10:09 AM   #2
68 short step
Re: Neat comp cam selection program
got a more specific link???
68 short step is offline   Reply With Quote
Old 11-25-2007, 10:50 AM   #3
Buffrock
Buffrock's Avatar
I checked it out, you need to download the program (comp cams software) 20MB, after you install it you need to enter all your engine specs( heads, flow, valves, basic cam selection, intake & flow) pretty neat if you have that information.
Buffrock is offline   Reply With Quote
Old 11-25-2007, 12:18 PM   #4
Jim_PA
I built mine up, and the curves/numbers it produced looked almost exact to what Desktop Dyno did over on Billa's thread in the engine section.
Jim_PA is offline   Reply With Quote
Old 11-25-2007, 05:46 PM   #5
68caliRat
Need a bigger hammer..
Cool, saving that one for my 454 build.
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 11-25-2007, 07:43 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Cool, I downloaded and played with it a bit. I'm assuming it's roughly 20% or so above real life numbers. It's amazing what a good set of heads and a little bump in c/r will do for a motor!. I need heads,lol.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-26-2007, 12:56 AM   #7
Jim_PA
I doubt it's that far off -
Old 11-26-2007, 12:46 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
That's a cool little app, thanks for the link...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-26-2007, 02:12 PM   #9
snj8198
snj8198's Avatar
i monkeyed with it last night. for some reason it will not let me tailor the bore and stroke from stock. anyone else have this issue?
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 11-26-2007, 02:20 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
Try clicking on 383 stroker...
Beat it to fit,
Old 11-26-2007, 02:35 PM   #11
snj8198
snj8198's Avatar
i have a stoked mkIV block though. i select 454 and it wont allow me to change the bore and stroke. am i missing something somewhere??
Steve
Old 11-26-2007, 02:41 PM   #12
Sinister
Between Trucks...
Sinister's Avatar
I just stroked a 454 to 571. Click to the right of the bore or stroke and type in your numbers and hit return...
Beat it to fit,
Old 11-26-2007, 03:46 PM   #13
snj8198
snj8198's Avatar
ok...got it!
Steve
Old 11-27-2007, 12:21 PM   #14
snj8198
snj8198's Avatar
has anybody figured out the head selection on this program? i'm unsure what my Eddy 454-O semi-open chambers would be considered on the drop down menu.
Steve
