Old 11-25-2007, 08:50 PM   #1
The Hogdoctor
Inside Door Panel
I have taken out everything inside the cab of my 66 truck getting it ready to paint. I wanted to go back with something different on the inside door panels other than painting them the same as everything else inside the cab.
Does anyone have any pictures of what they have done to theirs?
The Hogdoctor is offline   Reply With Quote
Old 11-26-2007, 09:57 PM   #2
Dadsredwagon
Dadsredwagon's Avatar
Re: Inside Door Panel
Your looks great.. I painted my cab red and the door panels a off cream/white ...sorry don't have any pics right now.
Dadsredwagon is offline   Reply With Quote
Old 11-27-2007, 11:35 AM   #3
04Xrider
Registered thread killer
04Xrider's Avatar
I used a texture paint on mine followed by a clearcoat. They seel it at wal-mart around $7.00 a can and lots of different colors to chose from.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 11-27-2007, 11:53 AM   #4
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Auto Zone has some rolled headliner material that is real easy to form/work with. Use it with some 3M spray adhesive. Spray the panel and the back of the material, let tack up for 30 seconds, work from the center out and your done! comes in tan, gray, red, or black - Jerry
ClassicAutoResto is offline   Reply With Quote
Old 11-27-2007, 12:10 PM   #5
salazar44
65 - Chevy C10
salazar44's Avatar
Or just find pretty much any fabrick you like. I used super 77 by 3m for the spray adhesive and it worked out pretty good.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 11-27-2007, 12:13 PM   #6
Rokcrln
Rokcrln's Avatar
Not to hijack but how was the fitment of your seats? Did you relocate the gas tank and if so how much leg room to it add? Thanks
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-27-2007, 01:35 PM   #7
04Xrider
04Xrider's Avatar
I can not tell that the gas tank on mine was ever in the cab. But these late model seats are a tight fit. I think it would be a problem for anyone over or close to 6'. You could still bolt them in even if the tank was in the cab, and still have some room for adjustment, just not sure how much.
