Suburbans RULE!
who's bought 'em, where and how much?
Right now LMC has the best price at $20 each. Has anyone else found them cheaper? ------------------ 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, Scat crank, H-beam steel rods, KB Pistons, Speed-Pro Moly Rings, Clevite bearings, Speed-Pro High Volume oil-pump, Comp Cams 254H 4X4 Xtreme cam, SR Torquer 2.02/1.60 heads, Comp springs, Trick Flow pushrods, Comp Roller Rockers, Edelbrock Performer RPM intake, 3310 750cfm Holley, Summit HEI, MSD 6AL, Built TH350 Transcat Supper II shift kit 2000 RPM Stall, 4" Rough Country Lift....etc.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
