11-26-2007, 06:19 PM | #1 |
5/7 Drop
Anybody have pic's of A 5/7 drop??? Wheel and tire size would be nice. What you used to get that low.Thank You!!!!!!!!!!!!
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
11-26-2007, 06:49 PM | #2 |
Re: 5/7 Drop
Yes.....Like to see some low static drops with wheel/tire sizes, maybe offsets, and any probs with it being that low.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
11-27-2007, 03:12 PM | #3 |
Re: 5/7 Drop
ttt
11-27-2007, 03:17 PM | #4 |
Re: 5/7 Drop
I have a 5-inch drop on the front but I have not lowered the rear yet but for the front I
installed 2.5 inch drop spindles, 1.5 inch control arms and 1-inch drop springs (actually cut 1/2 round totaling 5-inches! The frontal shot is on my profile but i cannot seem to find the best photo of it.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
11-27-2007, 08:38 PM | #5 |
Re: 5/7 Drop
ttt
11-27-2007, 09:04 PM | #6 |
Truck Enthusiast
Re: 5/7 Drop
My truck HERE 4.5"/7 drop.
Front: 2.5" spindles 2" springs Rear: 5" springs 2" blocks 20x8.5 & 20x10 255/40/20 & 295/40/20
'85 swb Last edited by droppedgmc; 11-27-2007 at 09:05 PM. |
11-27-2007, 09:46 PM | #7 | |
I have a radical idea!
Re: 5/7 Drop
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
11-27-2007, 10:08 PM | #8 |
Truck Enthusiast
Re: 5/7 Drop
nope, stock swb chassis and bed. maybe it's the wood bed? she's bolted down tight.
'85 swb |
11-27-2007, 10:18 PM | #9 | |
Chevy Truck Addict
Re: 5/7 Drop
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
11-27-2007, 10:49 PM | #10 |
Re: 5/7 Drop
Oh, OK. That makes sense. I had trouble with this when I mounted the bed on my '67 C-30. I cut the frame to 127" wheelbase and I added a bed to a cab and chassis truck that never had one from the factory. I measured stock bed mounts, but I ended up having to make mine about an inch shorter to make the body line on the cab and bed line up.
11-28-2007, 12:59 AM | #11 |
Re: 5/7 Drop
my truck was like that to, i think the cab mounts sag some also, i have one with old cab mounts, and one with new ones and the new ones line up much better. the rubber must deteriorate or somthing.
11-28-2007, 01:06 AM | #12 |
Re: 5/7 Drop
Here is my 72 gmc with a 5/7 drop. Front has 3" belltech drop spindles & 2" eaton drop coils. Rear has original leafs that were de-arched 7". I can't remember for sure but I think 1 or 2 leafs were also removed. I also c-notched the frame. I'm using kyb shocks all around. Wheels/tires are 18x8 with 255/35/18 and 18x10 with 285/35/18. Hope this helps.
11-28-2007, 08:17 AM | #13 |
Tot Roddin'
Re: 5/7 Drop
Do you guys have any issues with running 5/7? Wheel issues, rubbing...?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-28-2007, 11:43 AM | #14 |
Re: 5/7 Drop
I wonder if I would have rub issues with the 5/7.
11-28-2007, 11:36 PM | #15 |
Re: 5/7 Drop
I think tire size and wheel offset are the biggest issues. I can't remember the offset on my wheels but even with the 35 series tire - which is pretty low profile - I have no rubbing issues. I can turn all the way left and right with no problems. I was actually suprised at how well the truck rides with that drop and low profile tires. I've only put on about 100 miles on this truck since the resto, but have not bottomed out or scraped the exhaust on anything.
11-28-2007, 11:51 PM | #16 |
Re: 5/7 Drop
F= 2.5" Spindles + 1-coil cut from original springs; 15x6.5 van ralleys w/215/75-15's (27.7" tall).
R= 2600# bags, 1.5" blocks, modified rear shock brackets, bolt-in c-notch, adj panhard bar, hole in the bed-wood just above the rear-pumpkin; 15x8" truck ralleys w/255/70-15's (29.0" tall). Exhaust professionally 'plumbed' & tucked-up within an inch of the body & front sway bar mounted directly to frame rails vs. sway-bar stanchions. Front tires buzzed the inner wells on big bumps/dips (especially @ high speeds).
12-04-2007, 11:17 AM | #17 |
Re: 5/7 Drop
