Old 11-26-2007, 08:52 PM   #1
87Bob
Question Adding a cargo box light
Has anyone added a cargo box light to a 85? If so what did you run into?
87Bob is offline   Reply With Quote
Old 11-26-2007, 09:02 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Adding a box light
What is a "box light"? Are we talking a third brake light, or something else?
bigblock73 is offline   Reply With Quote
Old 11-26-2007, 09:11 PM   #3
bigtruck81
most likely a cargo light
bigtruck81 is offline   Reply With Quote
Old 11-27-2007, 08:48 AM   #4
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
I like the idea that I suggested a while ago of running LED strip lights along the under side of the bed rail. I'm seriously thinking of doing that when I swap out the body on the '81.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 11-27-2007, 11:33 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
On my truck, I put in the round license plate lights on each corner of the bed. I drilled the large holes with a hole saw and then wired them to the license plate light wiring harness. This allows me to see under my tonneau cover at night and let the Security guard see in my bed when I enter my work place. The lights are shielded on one side and they can be turned to illuminate the bed and not shine in your eyes. They are on, when the lights are on, but could be wired to the dome light circuit with the use of a relay.
piecesparts is offline   Reply With Quote
Old 11-27-2007, 01:16 PM   #6
87Bob
I was refering to a cargo box light, the one on the back of the cab. My 85 dosen't have one.
Old 11-29-2007, 11:18 PM   #7
75gmck25
I picked one up from the junkyard, including the switch, wiring and connectors, and it was fairly easy to install.
- You will need to cut/drill a hole where the light mounts, but the hole just needs to be big enough so the light will mount flush. Exact location is not critical.
- Then drill another hole where you want to mount the switch on the driver's side door pillar. Again, exact location is not critical.
- Then fish the wires down from the light, between the two layers of the cab and pull it out in the corner behind the driver's seat. From there you just plug it into the existing wiring and into the switch. I cut the connectors off the wires, fished them through, and then put the ends back on using crimped connectors. This made it a lot easier to push the wires through between the two layers of the cab.
Bruce
75gmck25 is offline   Reply With Quote
Old 11-30-2007, 04:12 PM   #8
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
I added a cargo light to my '77, but just wired it directly into my dome light. I figured that even if I had put the switch inside, it'd probably be on all the time anyway.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 11-30-2007, 06:06 PM   #9
piecesparts
I purposely ditched my cargo light and replaced it with a brake light fixture off of a Nissan. The orignal cargo lights always looked bad and was a mess to keep clean. The cargo lights were of no use to me and the brake light helps me keep LITTLE old Ruthy "I can't see well" from hitting me in the rear end. I used the Nissan light because it was clean, neat and easy to mount. It foloows the lines of the truck well and works great. If I want light in the bed, I install just that light in the bed and not on the cab.
Old 11-30-2007, 06:11 PM   #10
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
u mean glove box light
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
