Old 11-27-2007, 03:28 AM   #1
rn2fine
rn2fine's Avatar
Column Auto Shift Handle Problem
I have a question about my C10 auto trans shifter. In recent months it has become very difficult to pull back on the column handle. Once it is back it moves to RND21 just fine. Any thoughts or remedies for this problem.
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 11-27-2007, 05:22 AM   #2
lbpd719
Zappaphile!
lbpd719's Avatar
Re: Column Auto Shift Handle Problem
are you parking uphill and putting pressure on the pawl?
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 11-27-2007, 05:51 AM   #3
JimKshortstep4x4
It sounds like the shift tube is sticky so I would suggest lubing it at the top and bottom. Spray top and bottom areas with a penetrant. On the top it works to spray the penetrant into the shift lever hole as you can usually hit the sliding points.
The bottom is more accessible so it is easier to hit the spot that moves up and down.
The alternative would be to dissassemble the column and apply a lube on the areas that slide.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-27-2007, 09:25 PM   #4
dave2953
Dave's not here, man
dave2953's Avatar
Mine was so stiff when it was cold that I had to use two hands to get it into and out of park. I sprayed WD-40 down the hole where the shifter is until it ran out of the end of the column. It's worked beautifully ever since.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 11-27-2007, 10:13 PM   #5
68caliRat
Need a bigger hammer..
Yup I had to do the same thing.
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 11-28-2007, 01:15 AM   #6
rn2fine
rn2fine's Avatar
Thanks everyone. I am going to try the WD40 trick tomorrow. Thanks again.
68 Chevelle
Old 11-28-2007, 07:38 PM   #7
71tahoe
71tahoe's Avatar
Lucky you it never gets cold in your part of the country. At about 40 degrees that gummed up lever can break the tip off inside the column. (Hope you're still parked in your driveway when it happens.)
Give it an extra squirt for me
71tahoe is offline   Reply With Quote
Old 11-28-2007, 08:40 PM   #8
69C10@16
Wait a tick....I have a 69 wit a th350....r u supposed to have to pull back on the shifter handle to git it out a park?????? b/c if so....mine just drops...push ever so slightly on the top and its in drive....it wont go all the way down into 1st either....but i thot that was just loose linkage and the shifter hit the stopper on the column b4 it got there....now im beginning to wonder.....any suggestions or idears?????? Dang it now im all worried....GRRRRRRRRR.
69C10@16 is offline   Reply With Quote
Old 11-30-2007, 01:36 AM   #9
rn2fine
rn2fine's Avatar
69c10@16, yep, you should have to pull on it before going from park to R. Its a safety feature and if yours is moving too freely I would talk with others around here to find out a fix. I am pleased to report that a few squirts of WD40 did the trick. Works great now. Thanks again for the great advice everyone.
68 Chevelle
