Old 11-27-2007, 05:39 AM   #1
pimperout
pimperout's Avatar
auto lock hubs
hey well i havn't posted on here for quite some time but i have an 87 4x4 and i was wondering if there were any good auto lock hubs, im gettin tired of the old manual hubs. do u guys know of any good aftermarket auto locks? thanks for any replies
________________________
68 chev K20 being converted to a cummins powered 70 GMC 4x4
09 jacked up mega cab (daily driver)
53 chev (someday project)
70 GMC (parts)
71 GMC (parts)
pimperout is offline   Reply With Quote
Old 11-27-2007, 12:36 PM   #2
jake60
Re: auto lock hubs
You might look for a set of Warn Lock-O-Matic hubs. Warn quit making them some time back but you see them occasionally on eBay.
"Common sense is very uncommon" Rudyard Kipling
jake60 is offline   Reply With Quote
Old 11-27-2007, 03:50 PM   #3
burnitdown612
Re: auto lock hubs
personally i would keep the manuals .. i have autos on my 87 and they have been nothing but trouble latelly .. they are only the oem silverado package ones but still the manuals are much more reliable.
1987 k10 silverado 305/700r4
burnitdown612 is offline   Reply With Quote
Old 11-27-2007, 04:50 PM   #4
jake60
Re: auto lock hubs
If you are interested in the Warn Lock-O-Matics, International Harvester used them as optional OEM equipment on their pickups. Those hubs do not have Warn stamped on them but has IH stamped on them but they were made by Warn. IH hubs are interchangable with GM.
Here's a photo of a set of Warn Lock-O-Matics for a Jeep that are presently listed on eBay....not my listing!
Old 11-28-2007, 08:13 AM   #5
Re: auto lock hubs
Lock-o-matics are weak in "auto" mode.Warn advises to "lock" for loads and compression braking.They fail to say why.I found out they can grenade when not in "lock" in any situation other than a quick need when rear tires will not get you by.4wheelin` in mud with rolling resistance put`s the same stress on a drivetrain as hauling a load.They are still great for their limited benefit if you can find some.I have one fairly unused one and parts of another from the second set after the first set grenaded.My score:Lock-O-Matics 3...Me 1.I just bought manuals and leave locked in if I know I`ll need off and on use,like patchy snow or an occasional mud hole in otherwise dry terrain.With manual or Lock-O-Matic hubs locked in you have "shift-on-fly" with better durability.
I have a set of factory auto hubs in working order off my`91 Suburban w/10-bolt axle I would sell.
Old 11-28-2007, 11:37 AM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
Re: auto lock hubs
I'm with special K on this one. I wouldn't have the auto locking hubs on mine. If it's snowy or I'm headed off road, the hubs get locked in. I'll leave it in 2wd as long as possible and when 4wd is needed I'll shift into 4hi on the fly.
It sure beats gettinng stuck when I needed 4wd and the crappy auto lockers decided to quit or break at the wrong time.
If you must have auto locking hubs, I'd suggest stashing a pair of decent manual locking hubs in the truck and the tools to go change them. This way if an auto locking hub does quit, you can stuff a manual on it and get out of whatever stuck you got into. It's not a matter of "if" the auto locking hubs fail, it's WHEN will they fail. With my luck the "when" is at the worst possible time.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 11-30-2007, 12:25 AM   #7
pimperout
pimperout's Avatar
Re: auto lock hubs
ok ya i have asked around here and i have heard the same stuff thanks for the replies i dont think i will be getting those anytime soon
70 GMC (parts)
71 GMC (parts)
