Old 11-27-2007, 05:48 AM   #1
pimperout
pimperout's Avatar
2wd to 4x4?
i have a a 2wd 70 GMC 1/2 ton i would like to convert to a 4x4 as a long-term project i was just wondering how hard it would be to convert and what needs to be converted to make it a 4x4 thanks for any and all replies
________________________
68 chev K20 being converted to a cummins powered 70 GMC 4x4
09 jacked up mega cab (daily driver)
53 chev (someday project)
70 GMC (parts)
71 GMC (parts)
pimperout is offline   Reply With Quote
Old 11-27-2007, 05:54 AM   #2
JimKshortstep4x4
Re: 2wd to 4x4?
Your best and easiest way to convert the truck is to obtain a truck 4x4 frame and running gear. It then becomes an easy swap out of sheet metal.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-30-2007, 12:21 AM   #3
pimperout
pimperout's Avatar
Re: 2wd to 4x4?
ok thanks for the reply
70 GMC (parts)
71 GMC (parts)
Old 11-30-2007, 02:01 AM   #4
69TowRig
Re: 2wd to 4x4?
I read about people converting 4x4 Blazers to 2wd all the time on here, doing the crossmember swaps and etc in a weekend or two. I don't see why you could not do the swap in the other direction just as easily.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 11-30-2007, 06:36 AM   #5
vtblazer
vtblazer's Avatar
Re: 2wd to 4x4?
Jim
WAY easier.
Find a 4x4 being parted out, you could get the entire truck and drive tran for alot less than you'll have into 1/2 the cost/effort of trying to do a conversion.
vtblazer is offline   Reply With Quote
Old 11-30-2007, 07:20 AM   #6
mrein3
mrein3's Avatar
Re: 2wd to 4x4?
Originally Posted by vtblazer View Post
WAY easier.
Further, I would look for a 1971 or 1972 4x4 chassis. That way you get disc brakes.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-30-2007, 08:18 AM   #7
RustyParts
RustyParts's Avatar
Re: 2wd to 4x4?
I bought a '73 4x4 rustbucket from a neighbor and used everything from it in my '70 C10. Took about a week. If you use the 2WD frame you'll have to drill the frame for the tranfer case mounts and the leaf springs. I also used the booster and proportional valve for the power brakes off the '73.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 12-01-2007, 01:47 AM   #8
biggreenchevy
biggreenchevy's Avatar
Re: 2wd to 4x4?
If you cant find a 4x4 frame it can be done with a 2wd frame tho i wouldnt recomend it you would need bothe axles, spring hangers, shackels, springs, trans and t case, trans crosmember, drive shafts, shocks, Front crossmember, on a two wheel drive wont clear the front axle, pretty much all the mounts off of a 4x4 frame
We once did it to a 83 crew cab did it in about two weeks, we worked on it every day all day Try findin a 4x4 crewcrab frame... next to impossibe!
Basicly just keep an eye out for a 4x4 frame lot easier and faster
just my 02.
chris
biggreenchevy is offline   Reply With Quote
Old 12-01-2007, 04:48 AM   #9
earl87gta
earl87gta's Avatar
Re: 2wd to 4x4?
here is some good reading for you .
http://www.geocities.com/scbeoffroad...ted/index.html
http://67-72chevytrucks.com/vboard/s....php?p=2267618
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
