11-27-2007, 12:32 PM | #1 |
Straight jacket required
Tilt column question
I had searched the FAQ and here, and I can't seem to find my answer. What is the difference between the mid 70's van and truck tilt columns?? I want a floor shift tilt column and was hoping these were the same fit, or maybe I could make them fit. I can only find info on the van columns. Thanks in advance and Happy Holidays everyone.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." |
11-27-2007, 01:36 PM | #2 |
its all about the +6 inches
Re: Tilt column question
the shaft on the van unit is a couple inches longer, and the neutral safety switch is up a little higher.
in all reality, that's about it. |
11-27-2007, 02:16 PM | #3 |
The van column is pretty easy really & making one smooth for a floor shift isnt too bad either. Here are a few links & a couple pics of the van tilt I smoothed for a floor shift. Ill have to do the neutral switch on the shifter though...
http://67-72chevytrucks.com/vboard/s...d.php?t=147355 http://67-72chevytrucks.com/vboard/s...d.php?t=133937 http://67-72chevytrucks.com/vboard/s...ad.php?t=63328 Last edited by corn; 10-10-2009 at 12:16 PM. |
11-27-2007, 02:53 PM | #4 |
Watch out for your cornhole !
Corn, you got PM from me
11-27-2007, 04:16 PM | #5 |
Thanks guys, that helped alot.
