Diesel in a '70 C-30
I am thiking about puting a diesel in a 70 C-30 350 4 speed to pull a 5th wheel camper. I was thinking to go with either a Cummins 6bt or 4bt with a RTO-6610 or a Detroit Diesel with the RTO-6610. I want a manual transmission. I have looked around and it seems like most people are using Cummins. Any ideas on what would be a good swap?
Re: Diesel in a '70 C-30
I wouldn,t use the 4BT. It is sluggish, vibrates & is noisey. The GM 6.2-6.5 are a bolt-in but unless you Turbo charge it they are a little sluggish.
Can you bolt the RTO6610 to a 6.2 or 6.5? I would want to turbo it tho thats why I was thinking Cummins or Detroit Diesel.
Do you happen to have that transmission already? If not, or you don't have one lined up, good luck getting one cheap. Most tranny rebuild places can get you one, but you need a core...and it will be expensive anyway.
I would just try to find a Dodge Ram with the NV4500 or NV5600 and just swap the entire drivetrain (including rearend) to your truck. I am sure motor mounts wouldn't be that big of a problem. You could also do the same thing with a 6.5, just find a donor truck. I think that with any of the small Detroits (well, small enough to fit inside a 1 ton truck), the 4bt, or the 6.2, you will find it lacking in power to tow.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
I'd rather be Cummin than Strokin, so stay away from a PowerJoke and who really wants a chevy diesel anyways. Run the Cummins 5.9 and get a power programmer. I have a 2001 Dodge with an Edge Pro Comp programmer and it is a workhorse and will lay all the rubber you want to part with. Tires do get a little expensive though.
Rottenwood Garage Member
There are about 6000 posts about this very thing here on this site. Check the archives.
Some like GM Some do the Cummins I prefer the Cummins and have plans for a 4TB in the near future.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#7 | |
One Tons all the way! 67 chevy C-30 383 Stroker Reg 2wd 133wb 97 Ford F-350 7.3 Powerstroke Diesel CW Cab LB 4wd Last edited by 1tons4life; 11-27-2007 at 10:12 PM. Reason: new in fo |
I think that a Cummins is the motor to go with but the transmission is still up in the air.
The 70 GMC has a daully rear end so if I were to find a doner truck I would need to get a dually doner. |
Just find a totalled out Dodge dually in the junkyard and take the whole drivetrain. Then all you have to do is have the driveshaft cut to length. If you are going with an auto you may want to have the transmission gone through and put in a shift kit. That is the weak point. Good luck Jyard diving.
I do want a manual preferably a 6 speed.
Rods
![]() Join Date: Nov 2002
I have an old IH 7.3 sittin in the back yard.9in the van still) I have thought about using it.. not sure just yet
Just a thought, I found a wrecked 2002 Chevy Dump Duramax w/ 62k miles for $11,000.00. Has anyone put a Duramax in a 70's truck?
What would be easier Cummins or Duramax? I know the Duramax has a lot of wiring but if you have a full parts truck, that should make it easier. |
#13 |
theres alot of wires to it but the benifets are great a older cummins is easier but does not have the power or the upgrades.
One Tons all the way! 67 chevy C-30 383 Stroker Reg 2wd 133wb 97 Ford F-350 7.3 Powerstroke Diesel CW Cab LB 4wd |
#14 |
What manual transmissions bolt up to the Duramax?
I guess I could just drop the 70 GMC cab on the 2002 Chevy's chassis if the frame is good. Last edited by 77GMCSerria; 11-28-2007 at 11:55 AM. |
#15 |
im not sure which it is but i would look it to another one anyways the 6 speed that goes behide it suck the clutch is #### and the trans is hard to find do to chevy will not put it in anything other there the stripped base models anything above a base and its a auto. look in to ford or dodges 6 speeds or the old deisel 5 sppeds I dont now if it will work but chevy 6 speed is not worth the trouble.
#16 |
I think I'll just stick with the Cummins.
#17 |
its easier thats the way i would go
#18 |
For the transmission I was going to go with either a Eaton or NV5600 or the ford ZF6 (6 speed).
#19 | |
r 1 3 5 l 2 4
#20 |
If I use the ZF6 from a diesel what clutch and flywheel would I use?
#21 |
Just put you a 396 or 454 Gas engine in it, with a 400 trans and pull what ever you want to. Besides Gas is cheaper than Diesel .My 68 C10 has a 396 with 400 and I have carried and pulled anything I wanted to with it.
98 Chevy Z71 1500 extended cab 99 Dodge carvan es 68 Chevy C10 LWB 50TH 396 eng 400 Trans 62 Wheel Horse tractor in good shape |
#22 |
I want a Diesel, even tho gas is cheaper than diesel you get more miles per gallon with diesel.
#23 | |
I have a radical idea!
BTW, here's a 10-second '70 C-10 with a Duramax! http://www.dieselpowermag.com/featur...max/index.html
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#24 |
The only reason I was thinking about using a Duramax was that there is a 2002 Chevy Dually Dump with a Duramax w/ 62k miles at a local junk yard. He wants $11,000.00 for it. But I want a manual transmission, I don't know of any manual transmissions that came mated to a Duramax.
#25 |
Aluminum slot wheels rule...
This is the first time I've ever seen anyone call a 4bt cummins sluggish. 275lb. ft of torque is sluggish for a 239cu. in 4 cylinder? and thats stock, you can juice them up more than that.
