Old 11-27-2007, 02:40 PM   #1
David Flores
David Flores's Avatar
Attatching Inner Fender Seals
They were attached with what looked to be staples from the factory?
What have you guys done when putting on these new seals?
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 11-27-2007, 11:27 PM   #2
David Flores
Re: Attatching Inner Fender Seals
Anyone? I want to get this done tomorrow evening.
66 c10 swbfs
My Build.
Old 11-28-2007, 06:26 PM   #3
LIVE RUST
1966 Chevy/GMC Mongrel K10
LIVE RUST's Avatar
I bent up my own staples using 1/16" soft steel wire (mechanics wire), drilled out the holes to 1/16", pushed the staple through then peened over the ends with a hammer and dolly.
LIVE RUST is offline   Reply With Quote
Old 11-28-2007, 06:41 PM   #4
mbgmike
I use s/stl paper clips so they do not rust and curl them under with a pair of needle nose. We do sell the staples if you want a more factory look that no one will see. They come in a brick just like normal staples.
mbgmike is offline   Reply With Quote
Old 11-28-2007, 07:43 PM   #5
72402
I glued mine on with weatherstrip adhesive. Much cleaner look.
Frank
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
Old 11-28-2007, 09:30 PM   #6
David Flores
Frank
That's what I ended up doing. I just now finished actually.
66 c10 swbfs
My Build.
