for those of you who kept your m/c in the stock location under the floor(ive got a 55.5 )what kind of master cyl did you use and how did you mount it? . my truck has a 78 camaro clip and ford 9" that i just put some wilwood disc's on. the truck currently has a single res. master on it . i dont plan on using a booster and i want to keep the stock pedels coming up throung the floor , any suggestions? thanks , Brian
Yellow truck club
Re: master cyl. mounting ?
Check out CPP http://classicperform.com/
or Brothers. Both have kits for using the original brakes. I think you need a dual res. if running discs. Brian ... ![]() ps ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Overdrive club
I used the cpp master and booster assembly,very straight forward mounting and since i was running all new metal brake lines anyway that was n/p!!!!!And othere than crawlin under the truck and physically seein it it all looks stock,including the pedal!!!!!!!!
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
I used TCI's kit that bolted up to the stock location.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
polishing a turd
tci's kit looks the best, (strongest) i like the triangulation on the bracket
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
