What headers?
What headers will fit on a 350 truck with a 3 on the tree transmission? I dont want to move the linkage.
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
Broken Down
Re: What headers?
Assuming you are asking for headers for your 1971 Chevy Cheyenne in your signature I checked these out and looked on the application tab and in the standard transmission column shift section it said YES!! "but may require clutch linkaged modification" Hope this helps....
http://store.summitracing.com/partde...43+4294791244+
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” Last edited by kenm78; 11-27-2007 at 06:07 PM. |
Re: What headers?
Yes its for the 1971 Chevy Cheyenne. Is there any that you can use with out cluch linkaged modification?
That's right, it's Copper!!
Re: What headers?
Call Early Classic, www.earlyclassic.com
Re: What headers?
ttt
Has more rust than truck...
Re: What headers?
I had Dyno Max's on my 70, 3 on the tree. No shifter or clutch modifications required. I did need to re-route the front passengers side brake line because it was rubbing the header.
#7 | |
Re: What headers?
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
