Old 11-27-2007, 09:01 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Recipe for 6 lug disc brake setup 69 Chevy 1/2 ton??
can't really afford the $700 power brake/lowered spindle 6 lug setup that CPP/LMC/Chevy Duty advertises, so.......
is there been a "recipe" on what parts to buy, from a salvage yard/parts store?? has anyone come up with p/n's for these parts?
second, do I have to go to power brakes right away? anyone running non-power discs? that would cut some of the cost out if I didn't have to buy a power brake booster.
so I would need spindles, ball joints, bearings, disc brake calipers, discs, brake pads, flexible brake lines. anything else.
thanks for the help.
tcb-1 is offline   Reply With Quote
Old 11-27-2007, 10:25 PM   #2
powell72
powell72's Avatar
Re: Recipe for 6 lug disc brake setup 69 Chevy 1/2 ton??
All of the parts you can get off 71/72 or 73&up trucks with the exception of the rotors. I don't think anyone has come up with a salvage yard retrofit yet for 6-lug rotors. You'll also need tie rod ends. If you go the 73&up route make sure the donor truck has the 1 1/2'' thick rotors.
Go off spindle year for ball joints and tie rods.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 11-28-2007, 06:30 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I got the 6 lug kit from GMCPauls for $475. The only thing I had to buy was the disc brake style master cylinder which was $14.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
