Old 11-27-2007, 09:13 PM   #1
Lated
Lated's Avatar
Corvette Ram Horns
Will these http://cgi.ebay.com/ebaymotors/72-80...QQcmdZViewItem work on my 70 C-10 or would the dump being straight down interfere with the crossmember?
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 11-27-2007, 10:02 PM   #2
byrd
Union Electrician
byrd's Avatar
Re: Corvette Ram Horns
I thinkthere is a typo in the listing, because the corvette manifolds have a 2 1/2" exit not a 2"
They will fit,but it is a pain and will require some crafty exhaust work
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-27-2007, 10:06 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
As far as I know all Byrd is correct. All Corvette SBC ramhorns were either 2.5" or 3" not 2". They will work, but a custom built y-pipe will be required.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-28-2007, 06:25 AM   #4
Ace in the hole
They look like the ones used for 4x4's. I believe all the 4x4 trucks dump strait down, at least they do on mine.
Here is another place on ebay for them- http://cgi.ebay.com/ebaymotors/EXHAU...QQcmdZViewItem
they have the angled outlet ones too.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 11-28-2007, 09:11 PM   #5
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Those are just the common 2" rams that are sold for many chev vehicles, incl our trucks (4x4 & 4spd). The Ebay sellers like to use the "Corvette" on as many listings as they can...sounds special.
There were just a couple years of vettes, high HP, that used the 2.5" rams that flow much better than these.
The 2.5" can be used on 2wd trucks IF you use 45 degree mandrell bent short attaching pipes and a mini starter for clearance. Dorman makes/sells the 2.5 rams.
PICKMUP is offline   Reply With Quote
Old 11-28-2007, 11:00 PM   #6
BCOWANWHEELS
they did use 2" outlet ram horns on vettes that didnt have hi-po engines
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-28-2007, 11:19 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This is correct as the ones on my 74 are 2" and it has the l-48 low output engine. Most of the c-3 years have these. 68-82 .
I have the straight dumps on my 67 SWB and the passenger side exhaust pipe had to be dimpled to clear the CM. They were custom made for the PO so I can't say what stock ones might do.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-29-2007, 10:54 AM   #8
Lated
Lated's Avatar
Looks like I could get a set of 2.5" Vette ram horns from Midway http://www.midwayautosupply.com/m-11...fold-kits.aspx for $125 shipped less than half the cost of the tri-y headers I was looking at. Will the ram horns flow anywhere near as well as the headers?
Old 11-29-2007, 01:08 PM   #9
hotrodhomi
hotrodhomi's Avatar
This is by far the best deal I could find. If you can find a new set cheaper, jump on it.
http://www.performanceexhaustplus.com/
Part number 674-504
Manifold - 1963-62 5.4L (327 CID) Corvette Ram's Horn, LH, 2-1/2" Dia. $57.45
Part number 674-503
Manifold - 1965-62 5.4L (327 CID) Corvette Ram's Horn, RH, 2-1/2" Dia. $57.45
Subtotal : $114.90
Shipping (Free Ground Service): $0.00
Tax : $0.00
Total : $114.90
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 11-29-2007, 01:45 PM   #10
Curbstone Mech
Active Member
I got my set from pickmup, all cleaned up, painted, with the manderel bent 45deg pipe. They made my engine howl!
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 11-29-2007, 01:53 PM   #11
hotrodhomi
hotrodhomi's Avatar
he was sold out when I was looking. the mandrel pipe can be ordered for about $15. Just ask for a 4" radius U bend made from 2.5" and cut it in half.
'66 impala ht
Old 11-30-2007, 11:43 AM   #12
Lated
Lated's Avatar
Are you talking about the Pickmup that is a board member?
Old 11-30-2007, 02:35 PM   #13
Curbstone Mech
Active Member
Later-
That be he.
68 short fleet
700r4 351;1 posi
Old 11-30-2007, 04:42 PM   #14
Lated
Lated's Avatar
Hah! I just realized Pickmup had already posted in this thread.
Old 12-01-2007, 12:54 AM   #15
Mondo
Mondo's Avatar
Those 2 1/2in manifolds have molded in brackets for accessories towards the front. I don't need that and think it would look funny.
Wish I knew for sure those Speedway tube manifolds won't work on a 67 C10 smallblock... they're exactly what I was looking for.
Mondo is offline   Reply With Quote
Old 12-01-2007, 02:19 AM   #16
Classic Bowties
Always on the hunt...
The only years GM offered/installed the 2.5 exhaust manifolds on the Corvette was 1962-65, they were also installed on the Chevy Impala and like full size pass. cars of the same years if equipped with the 300hp 327, GM never made any 3" sbc ramhorns. Any of the center dumping SBC ramhorn manifolds in 2" or even the better flowing 2.5" will fit & work just fine on the 67-72 k series, no crafty or custom exhaust work is needed for use on 4wd's, the center dump clearance issue comes into play on some C series/2wd's pending motor position. Cb
Classic Bowties is offline   Reply With Quote
Old 12-01-2007, 07:37 AM   #17
Curbstone Mech
Active Member
Lated- No problemo. Where are you in md? I'm in Westminster.
Mondo- You can shave (grind) off the accessory bosses like pickmup did.
The kit he sells is very clean. I put a set on my daily driver GMC and it really woke up the tired 350.
68 short fleet
700r4 351;1 posi
Old 12-01-2007, 08:15 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Classic Bowties View Post
..... GM never made any 3" sbc ramhorns. ...
Ya wanna come measure mine? 63-64 327 FI Ramhorns....
Articles-
"Refining Sierra"
Old 12-01-2007, 12:57 PM   #19
Classic Bowties
No need to.... I can see & identify by your pic that you have got yourself a ground on/smoothed out set of 2.5" ramhorns. Yes, even the vette FI engines had the 2.5" outlets, heck for that matter even chevys mighty LS6-454, the L72-427 and even mopars elephant-426 hemi cars all came factory equipped (production models) with 2.5" outlet cast iron manifolds. Cb
Old 12-01-2007, 03:38 PM   #20
Lated
Lated's Avatar
[QUOTE=Mondo;2468307]Those 2 1/2in manifolds have molded in brackets for accessories towards the front. I don't need that and think it would look funny.
My somewhat less than acceptable (it's a pain to adjust belt tension) PO fabbed power steering bracket mounts to the brackets on the 2" ram horns I have now and it would be useful until a better bracket is available/affordable but I agree, it would look odd with nothing attached to it.
Old 03-12-2008, 03:32 AM   #21
cstanley
cstanley's Avatar
[quote=Lated;2468865]
can they be mounted reversed? where the bracket is at the back?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 03-12-2008, 03:38 AM   #22
hotrodhomi
hotrodhomi's Avatar
The can be mounted on either side. I cut the bracket off of mine.
'66 impala ht
Old 03-12-2008, 06:47 AM   #23
wibilly
wibilly's Avatar
corect me if im wrong but that bracket mount was used to mount the altenator when heads with no accessory holes[camel humps] how was the ac mounted on the right side i want 21/2" ramhorns and have several sets or camel hump heads but want to put the factory ac compressor on my 4x4
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-17-2008, 08:47 AM   #24
mexgrhd68
mexgrhd68's Avatar
Smile Re: Corvette Ram Horns
I have some on my 68, not those exact ones, but mine do dump in the center and no problem they fit perfect. They are on an 1984 305 engine out of a monte carlo.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 03-17-2008, 02:36 PM   #25
basketcase
basketcase's Avatar
Here's another option. Starting in 1981 the Corvette manifolds were made of stainless with a 2" outlet. '82s were 2.5". They have the same dementions as the iron manifolds. I took off the heat shields and AIR tubes, welded up the holes and used Eastwood stainless coating on them. I cut the flared end off of a couple of new 2" head pipes I had around of unkown usage and have a mandrel bend to cut up to point the pipe away from the crossmember.
I paid $35. for these from a friend that had them on Ebay. They looked pretty nasty but a little work was all they needed.
'69 swb stepside in progress.
'59 Corvette lifetime project
Last edited by basketcase; 03-17-2008 at 02:52 PM. Reason: Fat fingers and poor eyesight.
basketcase is offline   Reply With Quote
