11-28-2007, 01:45 PM | #1 |
Chinook Arch
Auto Meter Gauges in Dash - Ideas for Signal Lights?
Just installed a full set of Ultra-lite gauges in my dash, but I'm not sure what to do for signal light indicators now. I've been looking at pictures, but haven't seen too many that have tackled this angle.
Also wouldn't mind retaining the brake warning lamp and the high-beam indicator if anyone has ideas for those. Thanks, CR
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus. Elsie's truck 2.5" dual exhaust with Hooker Aero Chambers Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350 ECE drop 3.5/5 |
11-28-2007, 01:59 PM | #2 |
Re: Auto Meter Gauges in Dash - Ideas for Signal Lights?
oh yes we have...68 short step simply added led lights on my cluster when he did my build up. it's posted on this forum just read my build up and whooolllaaaa! http://67-72chevytrucks.com/vboard/s...d.php?t=244448
R.I.P. Killer 71 10/26/07 |
11-28-2007, 02:38 PM | #3 |
speedway motors has really nice very small indicator lights that i've used a few times for signals and hibeams// get a streetrod cat from them www.speedwaymotors.com
11-29-2007, 09:58 AM | #4 |
Radio Shack has LED's with a large diameter lens that fits
11-29-2007, 11:02 AM | #5 |
More Cowbell....
Maybe I am confused here....
Do you have a 3 hole cluster or a 7 hole one? I have a 7-hole, and used the factory locations. I made a cluster for HartRod and added 'check engine' and 'high beam' indicators using fiber optic cable thru 1/16" holes right above the fuel gauge....you can't even see them in the pic until they are on.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 11-29-2007 at 11:02 AM. |
11-29-2007, 12:46 PM | #6 |
Parts stores sell leds the correct size you can use in the original holes.
11-29-2007, 01:04 PM | #7 |
Always wrenching!!
superbrightled.com i have order alot of there stuff. always perfect.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
11-29-2007, 01:12 PM | #8 |
Licensed to Thrill!
Everyone I have seen putting gauges in a Covan's insert or similar just always drills them a couple of holes and pops some LED's in there.
I have always thought it'd be neat to have like three Ultra-Small LED's that did a progressive blink though. They'd have to be small, otherwise, it would look very bad. Fiber-optics would be the best. Same goes for Indicator lights. DLB |
11-29-2007, 11:06 PM | #9 |
Chinook Arch
I've got the 7 hole dash, currently holding 6 gauges. I have to find something to put in the center hole, probably use a blank black plastic sheet until I can find a clock or something to fill the middle hole. I believe I will mount the brake and high beam lights in there, I guess I'll go down to the Source and see if I can scare up some LED's.
