11-28-2007, 06:33 PM | #1 |
Hood Insulation
Anyone know how under hood insulators are installed?
Thanks, Dave
68 C-10 Custom LWB 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America Last edited by daveo68; 12-01-2007 at 03:29 PM. |
11-28-2007, 09:36 PM | #2 |
Re: Hood Insulation
ttt
68 C-10 Custom LWB 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
11-28-2007, 10:57 PM | #3 |
Re: Hood Insulation
Doing mine right now and should have some pics by the weekend or so.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
11-29-2007, 09:08 AM | #4 |
Re: Hood Insulation
Pics would be good. I saw in LMC catalog the hood insulation and was trying to figure out how it is installed.
11-29-2007, 10:05 AM | #5 |
Active Member
Re: Hood Insulation
What is the hood insulation for? Is it for noise?
It's so noisy in my truck cab, I can't hear the engine. I'm just running a stock 250. |
11-29-2007, 01:29 PM | #6 |
Re: Hood Insulation
Hood insulation really makes a difference when closing the hood and getting rid of that "tinny" sound.....makes it sound alot more solid. I also have a small supercharger on my motor that at idle has some gear lash that I hate the sound of and the insulation makes it inaudible when the hood is closed. The insulation also dramatically reduces heat transfer from the motor to the hood surface.
I'm using foil sided insulation and running it under the supports (got rid of rubber insulators), trying to make it look as nice as possible. I'll shoot some pics "if" it turns out like I want.
11-30-2007, 05:12 PM | #7 |
Re: Hood Insulation
I think LMC has the rubber insulators. This is what I looking at to install.
68 C-10 Custom LWB 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America Last edited by daveo68; 11-30-2007 at 05:13 PM. Reason: Spelling |
11-30-2007, 05:51 PM | #8 |
Re: Hood Insulation
You at least want those, otherwise the hood skin flaps up and down as your driving along!
12-01-2007, 08:34 AM | #9 |
Re: Hood Insulation
Do you know how that is installed? My hood has none of that.
12-01-2007, 03:31 PM | #10 |
Re: Hood Insulation
ttt
12-01-2007, 03:46 PM | #11 |
Re: Hood Insulation
Just use a small taper between the support and the hood to slide the rubber pieces in. SLiding the taper out compresses it between the hood and support, holding it in place.
Im thinking about Dynamating the underside of my hood, but it may look tacky...
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
12-01-2007, 04:02 PM | #12 |
Re: Hood Insulation
I'm waiting to see how SactoJim's turns out. If it works okay I will attempt to install.
68 C-10 Custom LWB 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America Last edited by daveo68; 12-01-2007 at 04:02 PM. |
12-01-2007, 05:36 PM | #13 |
Re: Hood Insulation
Here ya go Dave...
Just got done messing with it over lunch. It is a definate case of "function over form", but it does make a HUGE difference in the "tinny" hood sound (nice dull thud now). It turned out ok....pretty much what I expected, and I don't know how much better it could get with any of the foil backed products out there. You can see in the pic a piece of round aluminum rod at the hood ridge that I think I'm gonna attach to the hood structure just to make sure the insulation never sags. Watcha guys think?
12-02-2007, 07:40 AM | #14 |
Re: Hood Insulation
That looks pretty good, might have me a new project to attempt.
12-02-2007, 10:59 AM | #15 |
Re: Hood Insulation
Got the hood back on last night and boy, what a difference....nice solid "thud" when shutting the hood and it just about eliminates hearing the motor from the outside of the truck. Also eliminates most of the engine heat transfer to the hood exterior.
12-02-2007, 08:55 PM | #16 |
Re: Hood Insulation
Do you hear less from inside the cab?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
