454 Starter Question
Scanned the search results and found mostly SBC starter issues, so sorry in advance if I missed the answer to my questions below.
I think I have a 168 tooth, externally balanced flex plate on my 454. The block is tagged as a 1987 "CE" which I'm told is counter exchange (basically a warranty replacement block). Last year the starter went out and I bought a rebuilt starter from NAPA. NAPA offered several starters for me to choose from, none of which were labled for my CE engine. So I bought the one for a 70 LS-5 454. It fit fine but made some mild gear meshing noise when it started. Adding startershims only made it worse. Last week that starter failed and I'm wondering what starter I should be looking for to fit my parts. To make matters a little more confusing, I got under the truck Saturday to verify I had the 168 tooth flex plate. Counting teeth (from even with the block surface on one side to even with the block surface on the other (i.e. half of the full circle)) I counted 83 teeth. Doubling that puts me at 166 teeth, not 168. It just so happens that the Pontiac 455 has a 166 tooth flex plate, so, did I miscount my 454's flex plate or do I somehow have a 455's flexplate on my 454? I don't think Chevy produced a 166 tooth flexplate, did they? Also, once that's resolved, any suggestions on which starter would fit my CE 454 block? Thanks all.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
Re: 454 Starter Question
My first suggestion would be to recount the teeth on the flex plate.
The starter you got from NAPA should have been the correct one. It is possible that the gears meshed too tightly to start with which appears to be verified by the fact that it got worse with shims. I don't know what to think about the possibility of a Pontiac flexplate fitting a Chevy engine. If it were mine I would put another starter on it, check the gear clearance and try it. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
![]() Join Date: Nov 2007
Have you ever looked at getting a mini-starter? D&B electrical makes a good one and is inexpensive. Also, you can get a reman delco starter from autozone for a 99 chevy with a 454 that is good from what I hear. I just broke a starter bolt off my D&B starter so thinking of getting the late model delco reman unit.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
