![]() Join Date: Jan 2002
Door Seal Gaskets
I did a search and found a few responses on this topic. I just put new door gaskets in (Precision Brand) and now I can't even get the doors to close. I hate to have to adjust the doors out just to get them closed and was wondering if anyone else has had this problem and any idea's on how to fix it. I know the old gaskets were almost 40 years old but these replacement gaskets although they fit good seem way thicker and have a hard rubber piece in the top corner.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Re: Door Seal Gaskets
I put new weatherstripping on mine two weeks ago and have the same problem. I dont know if I could get the screws loose to even adjust my doors HAHA!!! I'll be watching to see what is suggested cause if not I might just shatter a glass slamming the doors.....
![]() Join Date: Dec 1999
Hey guys, I sell parts and offer Precision Brand because most people building trucks are looking for a good afordable price. I sell them for $35.00 a pair I also sell Soffseal and I will tell you it is the best on the market but nobody wants to pay the price. I sell them for $50.00 a pair. I just used all Soffseal rubber in my sons truck and the front and rear window seals and door rubber is the best fitting I have ever used but it is hard to sell because of the price but I will tell you every truck we build from now on will only have Soffseal!
Try leaving the windows cracked a bit and then shut the door. If they are making a good seal they can be difficult to shut without a good push. My 71 was restored nearly 5 years ago (not driven) and the doors are still hard to shut without a good push unless the windows are cracked. If they still don't shut well, then you will have to play with door's adjustment.
I bought mine local Dave's Truck Parts in NC. They were $35 for the pair and have the mitered corners. They feel fairly soft but must seal real tight. If the window is cracked it is easier.
How would one go about adjusting the doors assuming one can get the bolts loose? |
#6 | |
Retired Air Force 87-09
Thanks, Rich |
Not sure which ones you are referring to, but the ones I got for $35 are glue on. Similar to the ones in the LMC catalog.
#8 | |
67-72 Addict!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Ever heard of Beech Island??
I put new ones on my truck last week and they were real tight. The drivers side has gotten better, because I use it alot, but passenger side is still tight and have to push the door in when locking it. I figure this will get better with time. I should have put new ones on in the summer, so the heat would help them squish a little easier. I got mine from Brothers.
Is there a way to adjust the doors? My passenger door has to be SLAMMED and I'm afraid someone will beak the glass.
#11 | |
Fat Fendered Fleetside
Trust me, My trucks P.O. did a half-ass half-ass job!
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 Last edited by Mordachai; 11-29-2007 at 08:13 PM. Reason: :) |
#12 | |
Active Member
![]() Join Date: Jul 2007
I have an an original rubber gasket set that I bought some years ago but will hold of installing. |
