Old 11-28-2007, 09:01 PM   #1
69C10@16
85 Camaro Rear End???
Anyone ever seen or done a camaro rear end swap? What is involved in that? How about putting the disks from the front on my 69 C10? I seriously have no idea wut im getting into with this or if its even possible. It will take many long nights of research b4 i get to feelin like this is gonna happen. But I would like sum info. THANKS!
69C10@16 is offline   Reply With Quote
Old 11-28-2007, 11:47 PM   #2
69C10@16
Re: 85 Camaro Rear End???
nobody? really?
Old 11-29-2007, 12:36 AM   #3
Morgsie
Why would you want to? They're POS 7.5" 10 bolts... And just get discs. off a 73-87 GM truck, they bolt right on.
Morgsie is offline   Reply With Quote
Old 11-29-2007, 01:00 AM   #4
69C10@16
thanks for the info about the disks.....i didnt realize camaro rear ends were that bad....wut would u recommend for a rearend swap? keepin in mind that i plan on lowering it and i wont need hauling capabilities etc....
Old 11-29-2007, 01:48 AM   #5
68shortfleet
What's wrong with the rear end that you have now?
68shortfleet is offline   Reply With Quote
Old 11-29-2007, 11:47 AM   #6
nightmare
nightmare's Avatar
not only that, the bolt pattern is smaller. it's 5x4.75, whereas on a truck it's 5x5. or in your case, 6x5.5
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 11-29-2007, 04:49 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
small brakes, weak rear... no point at all.
If you have a 12 bolt 1/2 ton rear... or a dana, I see no reason to remove it unless you have 500+ horses.
Old 11-29-2007, 05:05 PM   #8
49m
49m's Avatar
Im going to try to put an 88 camaro rear end in mine because It is posi and it was free. The are the same spline and lenght i can just change the axles. For the same bolt pattern
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
Old 11-29-2007, 07:43 PM   #9
69C10@16
Well....mine is free too....but....I dunno. I think my theory wuz i have (if im right) a 1:3.73 rearend and the camaros wuz 1:3.42. I want it to be quicker from zero mph. I dont know. I doubt i do it. Just more crap that I dont need to do. I wanna lower my truck anyways so yeah....its probably not gonna happen. Wuts a cheap way to get disks out back? SOmeone above said I could go with 73-87 for the front and theyd bolt right on. Will that work 4 the back????
Old 11-29-2007, 09:18 PM   #10
Morgsie
Free isn't necessarily better. Sounds like a make work project to me.
Old 11-30-2007, 01:23 PM   #11
49m
49m's Avatar
Camaro coil springs make the truck sit lower.
My Rides
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
My Build Thread
Old 12-01-2007, 10:17 PM   #12
Morgsie
Why not just get new lowering springs? Or if you are trying to save money, cut the coils that are on your truck now. Again, sounds like a make-work project, where you think you're saving money but you're really just wasting time.
Old 12-01-2007, 10:22 PM   #13
Jim_PA
A 12 bolt truck rear has to be at least 3x as strong as the 7.5 from a camaro. Why do you want discs on the rear?
Jim_PA is offline   Reply With Quote
Old 12-01-2007, 10:28 PM   #14
arkracing
Weekend Warrior
3:42 (higher gear ratio) will make you slower off the line than a 3.73 (lower gear ratio, higher numerically)
if you do a lot of Highway driving then the 3.42's would be better. 3.73's are better for red-light racing (although the differance probably isn't as noticable as one would think between those 2 gear sets)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
