Old 11-28-2007, 09:13 PM   #1
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Building a stout 14Bolt Watts Link...what ya think ??
I came up with a few different "idears" for the Watts mounting at the pumpkin.
The first was to build a center mount off of the existing bolts....using 1/4" X 1" flat around the perimeter of the cover, welded together (or cut out a pattern out of a large plate), then build off of that. Kinda like this....
The second was to use spacers and long studs off the cover and build off of that.
So instead I decided to build an entire NEW rear-end cover out of 1/4" plate.....this would serve to hold extra gear oil, and a SUPER sturdy mounting point for the center pivot for the Watts.
After making this up, Rick (the owner) linked me to "totally-Polished" site and saw the polished Watts set-up...REALLY NICE...If he wants to go with that, it's cool...he will just has to ship it overnight...cause I need it like yesterday.
That being said, here are some mock up pictures...What you'all think ?? Strong enough ??
White line is direct center of axle.....mix-match bolts will be replaced with new (only short 3/8 I had in stock).....
I figure it would be perfect for the 'Rubicon trail'....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-28-2007, 09:32 PM   #2
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Re: Building a stout 14Bolt Watts Link...what ya think ??
Looks great John. Don't think youv'e got to worry about breaking it. I'd powdercoat it to finish the look. Good place to advertise your LOGO Too!
Jerry
ClassicAutoResto is offline   Reply With Quote
Old 11-28-2007, 09:40 PM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Jerry
I know...I need a logo first !!! (I have a logo idea, but that a different story)
The white line is where the lever will be mounted...not sure how it will be designed...I was thinking about using one of "Jesse's" stickers as a template, and making a cross in the center (I know, I know we are all sick of the WCC stickers)
Mabey a typical taper with holes....not sure. Lets see what Rich will want to do....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 11-28-2007, 10:07 PM   #4
rcrahn
rcrahn's Avatar
Looks good John! Thanks for the emails and explanations. I'm sold.
The TP kit is nice, it looks well engineered but its too fancy with all that polished billet. Plus I don't know if you read this but it would take at least 2 weeks to make. We can't be farting around here.
I like your approach, I think it will be functional and with powdercoat it will look fine.
Let's go for it!
rcrahn is offline   Reply With Quote
Old 11-28-2007, 10:20 PM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Cool man.....I'm on it !!!
Any others ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 11-28-2007, 10:21 PM   #6
62 short step
62 short step's Avatar
That looks nice and stout!!!
62 short step is offline   Reply With Quote
Old 11-28-2007, 10:34 PM   #7
rcrahn
rcrahn's Avatar
About the lever, I trust your judgement John to come up with a shape of something unique. That is if you want to.
Old 11-28-2007, 10:41 PM   #8
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 11-28-2007, 10:57 PM   #9
L0WRIDE
L0WRIDE's Avatar
great work as always chief
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 11-29-2007, 12:02 AM   #10
slepysal
slepysal's Avatar
sweeeeet!! Digging it !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-29-2007, 08:56 PM   #11
PrerunnerRob
PrerunnerRob's Avatar
Doh! I guess this is a little late...http://www.diy4x.com/drivetrain.htm
Oh, and they have a disc brake kit too! http://www.diy4x.com/brakes.htm
PrerunnerRob is offline   Reply With Quote
Old 11-29-2007, 11:35 PM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
We will definately need the rear disc kit for sure....
I just built this cover for a sturdy mounting place for the lever...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 11-29-2007, 11:59 PM   #13
Dinos63
chevy only
Dinos63's Avatar
nice work chief, you are a bad a--
Dinos63 is offline   Reply With Quote
Old 11-30-2007, 12:32 AM   #14
Rokcrln
Rokcrln's Avatar
For the lever how about doing a swooping "S" with the links mounted on each end of the "S". The links could also have a slight curve to them so they meet at the same level on the frame! I will try a pic.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-30-2007, 08:39 PM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I kinda like it.....
Kinda like the SUPERMAN S !!!
I like the idea about the bent links as well...but for adjustment I am going to have left and right hand threads on each link.
In all actuallity, I could just "set-it and forget it"
(I think I heard that one night on an info-mercial)
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 11-30-2007, 09:10 PM   #16
ClassicAutoResto
Rust Buster
The "S" looks cool to me John. If the logistics work, it would definitely be an original design and look. (Better patent it before someone else does!) Jerry
Old 11-30-2007, 10:53 PM   #17
Rokcrln
Rokcrln's Avatar
Opp's sorry it will not work like I have it drawn. The links can not meet at the same point on the frame, it will bind as it starts to move. The two links will need to be level from their link mounting point out to the frame.
But the LFD's S design will work fine. Feel free to use it on your project with out having to pay a usage fee this time
Kevin
LFD Inc.
Old 12-01-2007, 09:17 AM   #18
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Kevin
LFD Inc.
Thanks man.....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-08-2007, 09:01 AM   #19
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I went with a clean, simple lever design.....nothing fancy needed here...just burly looking.
Complete with a set of press-fit sealed bearings....
Working on the d-side mount now...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-08-2007, 06:23 PM   #20
PrerunnerRob
Super-duper sic! Any rules on link lengths vs moving bracket lengths?
Old 12-08-2007, 06:26 PM   #21
slepysal
slepysal's Avatar
MAN !! Thats crazy !! Nice job chief
Old 12-08-2007, 08:00 PM   #22
Rokcrln
Rokcrln's Avatar
looks great!! Were did you get the bearings with snap ring groves?
Kevin
LFD Inc.
Old 12-09-2007, 09:35 AM   #23
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks.....It all depends on your suspention travel....your truck will probably have a lot more travel considering where you have your bags. The lever doesn't really move that much. I might even make it shorter, due to the fact that the driver-side mount might be a little low. Then again, this truck won't be a frame dragger either.
Thanks Sal...as you can see, we are almost at home base.
Once I give him the "its done!" call, I'll have him come in for the final, I'll hit some switches for him.....he'll let me know what other holes he wants welded up, then I will disassemble, and prep for powder, then it's outta here !!!
Course, it will be back to haunt me again for the reassemble !!
I'll keep you posted Sal
Later
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-09-2007, 10:57 AM   #24
WELD4DAYS
Thats cool.I like making things heavy duty.You could throw that cover on a rock crawler! Looks good.
WELD4DAYS is offline   Reply With Quote
Old 12-09-2007, 02:25 PM   #25
Iron-Butt
454 club
Iron-Butt's Avatar
looks great
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
