11-29-2007, 03:11 PM | #1 |
Total newbie rear end question
I was researching ring and pinion gears for my newly aquired 63 SWB and realize I am just about clueless
Current gearing is 4.11 and I want to go to about a 3.38 give or take, open to suggestions also. Anyway I finally called Randy's Ring and Pinion for a quote and that's when I realized I am clueless. He asked if it was a 12 bolt rear and whether the gears drop from the front or rear. Uhhhhhhh, I dunno There are 12 bolts on the rear end but how do I tell if drops from the front or rear? Pardon my cluelessness |
11-29-2007, 04:03 PM | #2 |
Re: Total newbie rear end question
It might be easier to go with a overdrive transmission. If highway driving is what you're looking for. I've been told changing rearend gears can be quite tricky.
Tim |
11-29-2007, 05:12 PM | #3 |
Watch out for your cornhole !
You should be able to turn up a highway geared complete rearend out of a 63-70 model truck. This would keep your six lug bolt pattern wheels and be super easy and cheap. A lot of the trucks came with 3.08 gears. My 64 has them stock. I know it's not the exact ratio you're wanting, but they cruise real nice and swapping a complete rearend is cake compared to going inside of one and swapping the r&p.
11-29-2007, 05:51 PM | #4 |
I'm not set on the 3.38 ratio at all. It was just the only gear set Randy's had to offer.
How do I tell if my rear end unloads from the front or rear? I'd be open to a total rear end swap if I could find a suitable candidate. |
11-29-2007, 05:58 PM | #5 |
A shortbed will have rear loading gearset. The heavier trucks, like 3/4 and 1 tons used a drop out centersection that comes out the front of the differential.
The 67-70 model guys pretty much give 6 lug rear ends away. They all want to convert to the later model 5 lug stuff instead. I've sold a many of them for 50 or 100 bucks. Just search out a 1/2 ton rearend from a pre 1970 model truck that has the desired ratio. They typically came in 3.08 and 3.73 gearing.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-29-2007 at 06:01 PM. |
11-29-2007, 07:14 PM | #6 |
I just bought a 3.38 from Randy's to replace my 3.90. Here is a post that might help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=264941 Last edited by fuelpump; 11-30-2007 at 06:09 PM. |
11-30-2007, 04:49 PM | #7 |
Thanks.
Did you do the swap yet? How much of an inprovement did you see? |
11-30-2007, 06:08 PM | #8 |
12-02-2007, 04:25 PM | #9 | |
60-66 Nut
Just a FYI regarding gears and RPM's. In my '66 Burb I have 3.42 gears and I'm running 275/60-15 tires and at about 65 mph the engine is turning 3200 rpms The earlier 1/2 ton rear ends which were used up through '62 had a round rear cover with 10 bolts and a drop out 3rd member on the front side that also was bolted to the housing with 10 bolts.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 12-02-2007 at 04:29 PM. |
12-02-2007, 07:19 PM | #10 |
454 club
I went to a 308 rear end out of a 1972 truck so I could have the 5 lug set up. With the 454 / 400 auto it cruises at high speeds with low rpm all day long.
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
12-02-2007, 09:17 PM | #11 |
A related question on rear end swaps:
When looking for a swap candidate, how does one determine the ratio? Is there an imprint or code stamped somewhere, or do you have to pull the cover and do some math? hope this isn't too far off topic.. -matt
1962 Chevy Fleetside
283/TH350 |
12-02-2007, 11:37 PM | #12 | |
60-66 Nut
The only way I know of to be positive is to pull the cover. I myself have never seen any codes on the differential.
12-02-2007, 11:56 PM | #13 |
Once the cover is pulled, how does one go from there?
-Matt PS:Sorry for throwing in q's like this on someone else's thread...
283/TH350 |
12-03-2007, 12:16 AM | #14 |
60-66 Nut
Look on the outside edge of the ring gear for some numbers. There will be the part number, the date, and the number of teeth for both the ring gear and the pinion gear. they will be something like 11 41. that's 11 teeth on the pinion and 41 teeth on the ring gear. Divide 11 into 41 which is 3.7272, so that would be a 3.73 gear ratio. Let me know if you need any more help.
