Old 11-29-2007, 11:51 PM   #1
c10addict
c10addict's Avatar
Another KP notch post... Need advise from those who have one..
So I have read all KP notch post form days,months and years gone past and I still have some questions...
I order a KP notch this week and need to know what is the best shock location/set up to run??? I am running stocktrailing arms and bags in the stock spring location...
Second question, What did you do with the panhard bar?? New mounts? where?
Third question, I am running a 2 inch block and a 29" tall tire.. How much of the notch you think I'll need??? Should I cut it down a little??
Thanks!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 11-30-2007, 02:07 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Another KP notch post... Need advise from those who have one..
Alright! All your questions consolidated into one post. I'll bite.
Shocks- Everyone seems to have their own way of doing it. KP has an adjustable under axle bracket, suicidedoors has some similar. I didn't think that there would be enough length with them so I am going to try using stock trailing arm mounted lowers and put the upper mounts on the notch crossbeam.
Panhard- ECE or CPP super or whatever they call their full length bars these days. Stock frame mount on driver's side and trailing arm mounted on passenger's. Put the mount under your block.
Notch height- you would need the full 8"(and probably a little more) to lay frame on a 29" tire. I cut mine down to about 6" with a 3" block and the axle will hit the bumpstops just as the bags are fully deflated. You should be safe taking around 2" off the notch. I would measure to be sure.
Where are the pics of this new project?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-30-2007, 06:43 AM   #3
c10addict
c10addict's Avatar
Right now it is just a bare frame sitting in my garage and my cab and other sheet metal sitting in my other garage... Have parts laying everywhere!! Not too much to take pics of right now but I should have the frame done next week and will throw some pics up... Thanks for your help!
Old 11-30-2007, 08:01 AM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
This is what I did....I used the original lower mount, moved it forward one hole (on the u-bolt).
I ran shocks off of the notch....drilled and tap for the shock mounts.
Worked out great. In this set-up, I am also running the bags in the stock location, however I have set this up so with bags removed, and the axle bottomed out in the notch, there is still plenty of shock travel, from compressed to a fully extended bag state.
I wanted the shocks mounted at the axle, straight up and down, as they are more efficent this way...Here are some pics
You can see the rest of the build by clicking the second link in my sig..
The shocks are working perfect...plenty of clearance.
I am going to drill and tap extra holes for adjustment location of the upper shock mount. This top hole is to be used if we ever go with a 'canti' set-up in the rear. The hole we will be using is actually going to be 3" lower...this will allow max lift with the bags in the stock location (the way were running it)
You can run a panhard...but in this case we are running a stout Watts...
Also, as I mentioned, we are running the bags in the stock location, with 2" blocks....and the axle will never up that notch...I cut it down considerably.
With the bags deflated (3") The top of the axle is about half way up into where the originall frame would of been.
I could of cut the notch down even more, but just in case we go with a lever system in the future, well be able to use it.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-30-2007, 08:46 AM   #5
c10addict
c10addict's Avatar
thanks Cheif Rocka! What size are the shocks you are running?? Looks like an easy solution! Nice work!
