How low with a cpp c-notch
I wanted to know how much can I lower my 69 Suburban with a cpp c-notch, It states that I need one for a 4" to 5" drop in the rear, I want to go 6.5" to 7". will this work? If I need a taller notch, who makes one with the correct frame shape.
John 69 Suburban 350 V8, 400 Trans, Lowered, 4w Disc Brakes, 55 belair dash 87 & 88 Conquest TSi 2004 Jeep Liberty Renegrade |
Chevy Truck Addict
![]() Join Date: Aug 2006
Re: How low with a cpp c-notch
You should have no problem at all with a c-notch and a 7" drop. The pumpkin on the rear end will bottom out on the floor long before the axle bottoms out in the notch. I have air bags on my truck and wanted to "slam" it as much as possible so I bought a short compact-style bumpstop to install in the notch. To make a long story short, I had to use a taller bump stop because of the differential.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
If you want to go lower KP Components makes a formed notch for the trucks.. I have one ordered right now.. Just search KP step notch on here and you will see lots of pics..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
I have a 8" static drop in the back of my truck right now with a CPP bolt-in c-notch and it rides great. No clearance problems.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Seņor Member
Unlike the truck bed, the Suburban floor will limit pretty quickly, IIRC.
#6 | |
Junior Member
going to sell this one...looking for a SWB project next. |
Seņor Member
Pumpkin will hit bed floor before you use all of a c-notch. Wood bed is worse than steel bed, but both are affected.
XXL is correct, it will hit the floor before you bottom out in the notch. You could get some taller bump-stops to keep it from hitting, it would still get you about 1.5-2 inches lower than no notch.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 12-04-2007 at 05:41 PM. |
Junior Member
How hard to install the notch kit? I want the xtra 1.5"
It's not that bad, with the exception of getting the rivets out of the way. Rokcrln did a good how-to on here, the directions that come with it SUCK!
http://67-72chevytrucks.com/vboard/s...d.php?t=195566
mine is set up that the top of the rear end housing is just touching the bottom of the bed "steel" floor....
someday it will be done!
For what it's worth,I built my own 2.5" notch and when aired out there's 1/8" clearance between the axle and notch (no bumpstops just yet) and the dif sticks through the bed floor 3/4".
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#13 |
i have a cpp c-notch on mine.
#14 |
You can do an under bed weld in notch
#15 |
Seņor Member
Why? There's no gain in clearance beyond what you get with the CPP-type bolt-in.
#16 |
![]() Join Date: Apr 2005
This is my 69 Burb with a CPP bolt in.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-16-2007 at 04:36 PM. |
