11-30-2007, 04:19 PM | #1 |
rearend question
I had to completely disassemble my 12 bolt rear for the powdercoaters including the pinion gear. So I got a estimate from a local shop to get everything in the pumpkin back together with new bearings, crush sleeve, everything from a typical rebuilt kit. They want about $300 for parts and labor. Is this average?
11-30-2007, 04:45 PM | #2 |
Re: rearend question
thats an average or a bit below to setup a 12bolt rear
11-30-2007, 06:43 PM | #3 |
11-30-2007, 07:07 PM | #4 |
If you don't have a posi carrier, you might as well have them toss one of those in there as well since you are paying for the set up costs.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
11-30-2007, 07:37 PM | #5 |
"Ochre Ogre"
I have heard of people getting it for $200 but in Minnesota is runs right at $300. I couldn't find anything less when I had a posi installed in a Dana 60.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
11-30-2007, 08:10 PM | #6 |
11-30-2007, 08:59 PM | #7 | |
Post a WTB since you are currently "blue". Most want the entire rear end and understandably no one wants to ship one, but since you have to set it up anyway and just need the carrier, you don't have any limitations at all. I'd say about $200 bucks + shipping and you are all set for a used one. Don't skip it, it's not a lot of addtional money and if you are going through all the cost to set it up anyway, this is one of the few upgrades that you need to do it right the first time as it makes no sense at all otherwise as an open rear end is less than $100 complete.
11-30-2007, 09:03 PM | #8 |
Keep an eye out at flEBay. I see them pop up there pretty cheap from time to time.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
11-30-2007, 10:55 PM | #9 |
12-01-2007, 04:00 PM | #10 |
The shop I used to work for charged 400 or so for a rebuild using all of your parts. Sounds like a good deal (as long as they do it right)
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
12-01-2007, 05:19 PM | #11 |
make SURE you measure and record your ring gear back lash & pinion bearing preload torque so when you reset-up your gears your can put them back EXACTLY as they came apart. this is very important.
bob
I BELIEVE IN JOHN 3:16 |
12-01-2007, 07:26 PM | #12 |
oopps. too late for that. I took everything apart for the poweder coaters without knowing. I did at least keep everything in the proper order and placement.
