Just like to part out trucks!!
Anyone with a V6 motor????
Anyone with a V6 motor in their truck, if you still have the spid label on the glovebox, can you tell me what the code and what all its says on there about V6's, especially 67's. Mine has a 351 but don't know what the label says. Didn't know if there was a difference 305 or 351 on there. Thanks for any help, Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
I have a radical idea!
Re: Anyone with a V6 motor????
I have a '67 Custom Camper with a 351E, but there is no SPID on the door., It actually looks like there never on was one (original paint, no sticky glue and no discoloration?) If you are trying to the decode the engine, the best way to tell is on the pad on the front of the block under the fuel pump. It will have 305E or 351E stamped on there (including the E). If you wondering about the truck you have, it is defintely a 351, you can tell by the exhaust manifolds.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Thanks, yes I knew I had a 351. I think my glove box sounds like yours, doesn't look like anything ever on it. I was just curious if anyone else had anything on their spid. Thanks Randy
![]() Join Date: Aug 2003
6 bangers were pretty much base model (not options) engines,so probably won't be on the SPID. They will be easy to pick out in the vin#,but not as a straight or V unfortunately. You won't see a 307 on the SPID either. I haven't,anyway.
I think the V6's were actually considered optional though Tim, because even in the GMC's, the 250 L6 was the standard engine. I don't know if they were on listed on the SPID's that way or not though.
![]() Join Date: Jul 2007
I thoiught the only one that was not listed on the SPID was the 250 I-6 everything else was an option. My 292 is listed on the SPID I would think they would have done the same with the 351 V-6. How rare was this motor in one of these trucks?
Oh well,just when you think you know a little.
CM1590D is the first part of vin. So 67 GMC's didn't have a spid? Just curious, Thanks Randy
Roadtrip!
![]() Join Date: Feb 2003
Randy, i have seen quite a few 67-68 gmcs that appear to have never had a spid label...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Randy, my '67 GMC was purchased unmolested from the original owner and it has no glovebox label or any evidence of it ever having one. In the vin.# I believe it will have a "W" indicating it had a V-6 when it was built. You could always look in the springs under the seat and see if the build sheet is still there. On '67 GMC's that is about as close as you can get to a SPID label. As mentioned earlier you can check the engine size on the front, left deck area. If it is a 351 Magnum the 4 bolts that join the carb. to the intake will not be of equal distance side to side comparing front set to back set. Also, 351 Magnum exhaust manifolds look like an I-beam, where as standard 351E manifolds are smooth and rounded.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
![]() Join Date: Aug 2005
My '67 never had a SPID either. Yes, CS models had the 250 as standard, 292 optional and the CM had the 305 standard, 351 optional. Wish I knew how many '67 351E's were built, but I have been told not too many. There were no U.S. '67 GMC CE pickup models, only panels and Suburbans.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
blood type; Retumbo
no SPID on my 68 either. it was as basic and un-optioned as possible. I even think the rear view mirror was a dealer installed option.
#13 |
According to GMC Pauls info the M in the model number iidentifies it as a V6.
http://www.gmcpauls.com/67-72_gmc.htm This is the only one I have that has any info about the 305 V6 but sadly the date piece is not shown. I wasn't aware that GMC didn't always add a SPID label, guess that why I don't have many of those in my collection. ![]() Learn something new everyday, good thread guys! Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#14 |
WOW, THANKS FOR ALL THE INFO GUYS!!!! I've never noticed a 67 without a spid, but I never get these in very often either. THANKS SO MUCH, Randy
#15 |
None on my 67 GMC either
#16 |
teeitup-M&M auto salvage in Topeka has a 67-68 GMC v-6 pretty much complete if you're looking for anything.
#17 | |
72 C30 Trailer Queen
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts Last edited by Chris H; 12-01-2007 at 01:35 PM. |
#18 |
BINGO! L23 is the rpo code! Thats one to save.
Jeff
#19 |
That way I get you make me one, you'll know what code to use!
#20 |
![]() Join Date: Dec 2006
Here's some real good info on the V-6. http://www.6066gmcguy.org/EngineData.htm
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#21 |
Hey Chris H
Did you notice the typo on the label? F51KA... SHOCK ABSORDERS |
#22 |
The SPID for the 67 GMC also shows the New Process 435GA instead the typical SM420. Does the 435GA directly bolt on or does it require a different bellhousing? Anyone ever attemped to upgrade to a 435GA?
#23 |
Mine came with the NP435-GA. It will bolt in directly in place of a SM420, although mine happens to be on the V6 bell housing. It has a shift pattern like a SM465 in which reverse is all the way over to the right and down.
#24 |
The NP435GA was the most common 4 speed behind the V-6's. GMC felt that the ratios were better suited for the V-6, and the 435's torque capacity was higher. The 435 was only used in 4X2's, if the truck was a 4X4, it would have had the SM-420. Also, the 351E was 4X2 only. I did see one 351E with a 3 speed behind it. I think it was an SM-326.
#25 |
No`67 GMC V8s made?
