Old 11-30-2007, 04:50 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
knocking coming from the front wheel
today i just put a brand new set of wagon wheels and 275/60/15 tire on my truck. i took it down the street and i started to hear and feel a knocking sound coming from the front passenger side wheel. when i applyied the brakes, it stopped and smoothed out but it would start again when i let off the brake. like i said, the wheels and tires are new. i also changed the wheel bearings a few weeks ago, but there was none of this going on. could the lugs be loose? what do yall think?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 11-30-2007, 05:13 PM   #2
sick69
sick69's Avatar
Re: knocking coming from the front wheel
The lugs would be my guess or a wheel bearing. Since you just replaced the bearings check the lugs first.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 11-30-2007, 05:13 PM   #3
cdowns
cdowns's Avatar
if you think lugs are loose take lug wrench and tighten
jack up that wheel use jackstand and grab tha tire and twist and turn and see if something is hitting or loose// did you use a cotter pin when you did bearings, is there clearance between tierod and wheel ,is there clearance between control arms and wheel, is there clearance between tire and fender
Old 11-30-2007, 05:37 PM   #4
crm318
crm318's Avatar
i used a cotter pin. i did remember trying to spin the rotor around with the wheel off. i was hard to turn in one spot and then it would spin around till it got to that on spot again. ill give it a look.
1972 Cheyenne
Old 11-30-2007, 05:45 PM   #5
76bonanza
76bonanza's Avatar
If you have disks could be the pad hitting a high spot on the rotor making it make a noise.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-01-2007, 10:52 AM   #6
Ole Blue 68
Ole Blue 68's Avatar
Is it knocking on turns or on straightaways too?
Ole Blue 68 is offline   Reply With Quote
Old 12-01-2007, 11:34 AM   #7
rlm316
rlm316's Avatar
Why don't you jack the front of the truck up and spin the wheel? You should be able to find the noise like that. You didn't tell if it is drum or disc. Check the back spacing and the wheel run-out. Look for shiny spots also.
rlm316 is offline   Reply With Quote
Old 12-01-2007, 02:59 PM   #8
crm318
crm318's Avatar
well it was some loose lugs. i was distracted by a phone call and must had gone on to a diffrent wheel. i tightened the lugs, problem solved. thanks for the input.
1972 Cheyenne
Old 12-01-2007, 03:19 PM   #9
70' GMC
HERE.......Somewhere
70' GMC's Avatar
If you over torque it you might have made it to tight so you might would want to get you a torquer that beeps we have one in autotech and we put the nut on with our fingers so it wont cross thread and then we use the air gun then we tighten with a torquer. hope theres some mechanics on here that can tell you cause its kinda hard to explain
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 12-01-2007, 06:53 PM   #10
brianthelion02
Overdrive club
brianthelion02's Avatar
DOHHH!!!!!!!!!Glad ya caught it!!!!!!!!!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 12-01-2007, 06:55 PM   #11
BCOWANWHEELS
time to pull everything back apart ASAP
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
