11-30-2007, 11:35 PM | #1 |
plug wires over or under?
For those of you that have your ram horn manifolds on a sbc. Do you run your wires over or back under and up? My 67 has been converted to HEI and it has some junk wires on it!
I want to put a set of Taylor's or MSD's on it but not sure which one's to get. I believe the 90 degree ends under would be better. I am going for a set of precut if possible as I hate to splice my own. Thanks! Mike
1967 Fleetside, Sanford and Son Special Ivory/Blue Vinyl, 350/TH-400/12-bolt |
12-01-2007, 12:15 AM | #2 |
Re: plug wires over or under?
I bought a set of Taylors "precut". They were too short to put in the stock position (under the manifolds) so I had to run them on top. If you want to put them in the stock position, I think you would have to buy the ones that you put the ends on yourself.
12-01-2007, 12:26 AM | #3 |
If you want to route your wires underneath ask for a set for a 78 Corvette.
That year used an HEI and ramhorns. I always end up with a couple wires that are too long but maybe I'm not routing them around the starter correctly.
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
12-01-2007, 01:24 AM | #4 |
Always on the hunt...
If you are after that oe look (I like ) with your later type hei dist. then ask for 75-80 corvette plug wires. Cb
12-01-2007, 06:45 AM | #5 |
Watch out for your cornhole !
I run the Vette wires and they work great. Pardon the mess, this is my 365 day a year, 100 mile commute daily driver.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 12-01-2007 at 06:47 AM. |
12-01-2007, 09:38 AM | #6 |
Thank you for the info. gentlemen. That is what I was looking for.
Mike
12-01-2007, 10:28 AM | #7 |
Sierra Grande Club
I'm going to use Kingsborne when I get ready to put my motor in.
They suggested sending my original in to have as exact duplicate made for the new HEI. But now I'm going to request the corvette wires. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-01-2007, 11:19 AM | #8 |
From the pics it looks like the wires to the front cylinders are going behind the manifold. Are there heat shields there to protect the wires?
12-01-2007, 11:50 AM | #9 |
"Trucks with Class"
Some guys do run them over the valve covers, where you can keep an eye on them.
I run BB wires with straight ends. They are easier to clean and the valvecovers can't leak on them like those under. I get trucks in here all the time with an engine miss from plug wires that are burned from touching the mans and you can't see the damage without removing them for inspection. Last edited by PICKMUP; 12-01-2007 at 11:51 AM. Reason: pics |
12-01-2007, 12:49 PM | #10 |
12-01-2007, 12:55 PM | #11 |
Love That '69
When I had my rams horn manifolds on my SBC I ran my ACCEL superstock wires around the back, under, and up to the spark plugs. The set I had was long enough to reach nicely with a little extra slack. Then I just used ties to keep them away from the manifolds.
Now with my Dynomax headers I run them around the back and drop them from above with some chrome bowtie linear wire holders on the valve covers. I also picked up some nice high temp fiberglass protector boots for them as well.
I AM CANADIAN!!!!! 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates Last edited by Classic69; 12-01-2007 at 12:57 PM. |
12-01-2007, 01:33 PM | #12 |
I am looking a the Taylor wires (part number 74606). They are designed for 74-80 corvette with the 90 degree boots. I plan on putting some heat shields on just to be on the safe side along with the dividers.
Also a good price at 47.00.
1967 Fleetside, Sanford and Son Special Ivory/Blue Vinyl, 350/TH-400/12-bolt Last edited by geoman; 12-01-2007 at 01:33 PM. |
12-01-2007, 03:13 PM | #13 |
I also used late 70's Corvette wires with good success:
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... Last edited by 69TowRig; 12-01-2007 at 03:14 PM. |
