Old 12-01-2007, 07:35 PM   #1
Magnuman
Another Wheels and Tire Thread
I am thinking about using the Boze Flex 6 -17x8 wheel in a rubbed satin finish.
The tire size that I want to use is a 265/70R17 or 32x10.5R17.
The rim that are on their now are 15's with a 33x12.5R15.
The rear wheel looks fine but the front sticks out past the wheel well which I am not happy with.
How do I determine the best size/offset for the wheel/tire combination?
Here are some photos of the conditions.
FRONT DISK BRAKES
REAR DRUM BRAKES
Here are the wheels:
Magnuman is offline   Reply With Quote
Old 12-01-2007, 07:42 PM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Another Wheels and Tire Thread
I guess you don't have any lift. I don't know if you're wanting opinions or not but mine would be to lift it to fit bigger tires with a 17 inch wheel. 35's on 17's look really good IMO. If it's just a street cruiser, go 4 inch lift. 6 inch does look a lot better but for the street all you need is 4 inches.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-01-2007, 08:00 PM   #3
Magnuman
Can you tell if there is any lift from the photos?
I haven't checked it real closely yet as it is not stored at my home.
A few that have looked at it thought it was lifted slightly.
The previous owner did not do anything but thought if anything it might be slightly raised due to a previous spring lift.
I really do not want to lift it any further off the ground than it it now, but I am worried about the size of the wheel/tire ratio.
Can you tell from this photo?
This is what the truck looked like before restoration.
Old 12-01-2007, 08:49 PM   #4
ABLAZN
Oh..never mind....
ABLAZN's Avatar
I am running 17X9 Centerlines with a 4.5 inch backspace. My tires are 315/75/17 and they do not set outside the front fender. With what you are looking at, I would say a 3.5 to 4 inch backspace would work quite well The nice thing about running 17's is that there is no issues with clearance on the tie rod ends or dust shields while using wheels with the bigger backspacing.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 12-01-2007, 09:13 PM   #5
Magnuman
Is your Blazer lifted?
Old 12-01-2007, 10:15 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Ummm is that wheel gonna clear the front lock outs??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-01-2007, 10:38 PM   #7
Magnuman
They make them so they do.
Old 12-01-2007, 11:34 PM   #8
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Yep, about 5-6 inches, I should have mentioned that.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
Sold.
THE STORY HERE
Old 12-02-2007, 07:28 AM   #9
Mike C
Mike C's Avatar
Anything more than 4 1/2" backspacing and you have to reallly watch rubbing on the springs in the front and on the tub in the rear, and that is on a 10" rim. 4 1/2" backspacking is almost too much for an 8" rim. 4 1/2" is zero offset on an 8 incher. For road use, a 12.5" tire is really too wide for an 8" rim for maximum tire performance.
One of the things about running big tires is you have to move them out for steering and tub clearance. At least run a 9" rim and you might pull it off without rubbing and flush with the outside of the fender in front.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-05-2007, 03:16 PM   #10
Magnuman
I just saw this rim in the newest Truckin Magazine and thought it would look good on the Blazer.
I would have the centers painted black with orange pinstipping.
They come in 16x10 and 16x8 with 4.5 backspacee.
Is anyone running 16x10's on a non lifted truck?
Opinions always welcomed.
Old 12-05-2007, 03:32 PM   #11
jaros44sr
jaros44sr's Avatar
Really Old School, probably why I like it. Trim rings look good, or is that a chrome wheel with a hub cap?
Oops, sorry. I looked at the other side
Good choice
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-05-2007, 07:56 PM   #12
desertrat
desertrat's Avatar
Obviously it comes down to personal choice but I think running a small tire you need to be running 15" wheels.
Youre blazer is super clean, I would consider trying to find some supersingle II Weld wheels.
Also I was curious what size tire you are currantly running? They look like 33's.
desertrat is offline   Reply With Quote
Old 12-05-2007, 08:30 PM   #13
Magnuman
The rims that are on their now are 15's with a 33x12.5R15.
The fronts stick out, which I am not happy with.
I want to use a 16x8 with either a Baja ATZ radial 285-75R16 > 33x11.5R16
or Baja ATZ radial 265-75R16 > 32x10.5R16
