Old 12-01-2007, 11:39 PM   #1
Hoss72
Need your input
I found a 72 K-5 Blazer. It has a fuel injected 350 from a Corvette it looks to be done right, it has a 4" lift running 33" BFG's on American Racing rims. it has a soft top from some company out of Denver. From what I can see the drivers door is showing some rust coming to the surface.
My question is when I go to look at it to make him a offer what should I look for ? any spots more prone to rust than others. Any help you can give me would be greatly appreciated. I will try and get a few pictures on here so you can see what I'm looking at.
Hoss72 is offline   Reply With Quote
Old 12-01-2007, 11:50 PM   #2
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Need your input
welcome from s.a. Did you buy that blazer from gary? got any pics? Blizz, (my brother) bought his from gary. There are about ten of us from s.a. with these blazers. Me, Critter, Jtrux,Blizz,Levi72, Aj72, bigrey,herb101,Steve, and my cousin Jimmy. You gotta make it to the next K5 meet. Check out the Texas K5 Meet thread. Post some pics when you get a chance. Later, Mario.
BLUE THUNDER is offline   Reply With Quote
Old 12-02-2007, 12:00 AM   #3
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Re: Need your input
There are several trouble spots to look at for rust. First, pull the rubber seal around the upper windshield and look at the frame. These are not made in reproduction and are hard to find in good used shape. Also. look under any carpet or floor mats in both the front and rear bed area. Crawl under the rig and look at the rocker boxes. Those are most of the major areas to look for, but I am sure other will add to it. Remember, the body is the most expensive work to do on these rigs, so look at it first before making your decision. Good luck!!!
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 12-02-2007, 12:10 AM   #4
Hoss72
Re: Need your input
Blue Thunder , I haven't bought it yet but my mouth is watering. Yes is Gary's . I think . I have a 72 C-10 right now and I want something else
Old 12-02-2007, 12:15 AM   #5
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Need your input
All of these generation trucks and blazers had rust issues on the passenger side fender right below where the battery sits, check that spot out, also look for little things like doors closing correctly (can be adjusted but still nice to not mess with). The only reason I bring the doors up is because mine barely close with top off and close fine with it on. Also when you're over looking the truck look for certain rarities like tilt, tack, tow hooks (72 specific are pretty hard to find) and see if it has a center console and what kind of shape it's in. Those things always add value and some people don't know what they have. Good luck with your purchase.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-02-2007, 12:19 AM   #6
Hoss72
Re: Need your input
Thanks Jtrux I will look it over when I get a chance.
