Old 12-02-2007, 11:25 AM   #1
geoman
power steering conversion
I have no p/s on my 67. I just put new 255/70/15 tires on the front and will be rebuilding the suspension as well.
I want to upgrade to p/s because it is my DD and I have a bad shoulder so I need something a little easier to turn. What is the least expensive and easiest setup to bolt on.
I was thinking of getting a later model saginaw unit with new hoses but which box and pitman arm should I use (stocker?). Anything else I will need to change (i.e. steering shaft).
Thanks!
Mike
1967 Fleetside, Sanford and Son Special
Ivory/Blue Vinyl, 350/TH-400/12-bolt
geoman is offline   Reply With Quote
Old 12-02-2007, 02:49 PM   #2
bobthecop
bobthecop's Avatar
Re: power steering conversion
You will have to modify the frame to use a factory set up. There is no indention for the steering box.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 12-02-2007, 04:42 PM   #3
Guy58
Smile Re: power steering conversion
geoman,
Good luck with your conversion. I have a 1967 C10 with manual steering too. I would like to go to power steering but from that first reply it sounds like it may be a little to involved for me. I do have a question for you about those new 255/70/15 tires. Are those tires the same size as the original tires that came on our trucks? Let me know how you make out on that steering project.
Guy
Guy58 is offline   Reply With Quote
Old 12-02-2007, 05:39 PM   #4
Wrenchbender Ret
Any 67 up to 87 steering box will fit. Use 67-72 pitman arm. To put one on a 60-66 you need an adapter kit. The 80 up used O-ring type hose connection while the older ones used flare fittings.
Wrenchbender Ret is offline   Reply With Quote
Old 12-02-2007, 06:26 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
If you look above your post you will see a search box just below the welcome Geoman
private messages. If you type in power steering conversion and click the go button it will bring up several pages of threads on the subject. The first two pages have enough info to explain how to do the conversion and have pictures to illustrate the topic. HTH
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-02-2007, 07:42 PM   #6
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
Its not too hard at all. I did it this summer on my 67. VetteVet is right, there is lots of info on how to do it. Make sure to get the right pulley and bracket setup for your motor, lots of info about that too.
OlChev67 is offline   Reply With Quote
Old 01-30-2008, 10:36 AM   #7
BenReed
I'm in the middle of the same project.
There are tons of pages and posts on the net, but these three are all helpful:
1. The Chevy Truck Page (Realistic DIY approach)
2. Power Steering Upgrade for a Task Force Truck
(or what they didn't tell you when you bought the kit)
3. (I think it was) Classic perform.com had a great article, but it doesn't want to load right now.
BenReed is offline   Reply With Quote
