12-02-2007, 12:04 PM | #1 |
1973 c30 camper special diesel engine question?
Hello All
I am new to the forum and was hoping someone could help me with this question. I bought a 1973 c30 dually camper special w/crew cab that has a diesel engine in it, can anyone one tell me what size or ID this engine would be if it was stock from the factory. If there is more than one type I can post some picture later to help. I need to install new glow plugs and do some wiring and just don know enough about this truck to get started. Thanks you very much for any reponce and help! Take care all. |
12-02-2007, 12:37 PM | #2 |
Re: 1973 c30 camper special diesel engine question?
Welcome to the site!
I sure wish I could help you but im not finding anything with a quick search. If your truck still has the RPO sticker in the glovebox just look at the code on it. Here are a few links that have decent info. GM dealer brochures chuckschevytruckpages I did check the RockAuto parts site and they did NOT list a diesel engine as an option for the '73 trucks.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
12-02-2007, 12:42 PM | #3 |
Diesels weren't an option in 73 from the factory. I'd start my guesses with factory GM diesels. A 6.2 or 6.5L V8 GM diesel will drop right into small block of big block V8 motor mounts and bolt to a Chevrolet pattern trans, so this is the most natural swap.
Pics will help us best identify your engine. Last edited by Pyrotechnic; 12-02-2007 at 12:42 PM. |
12-02-2007, 01:10 PM | #4 |
Thanks you all for starting the help, I have search Hi and low for info and come up empty.
On the A 6.2 or 6.5L V8 GM diesel is there any way to id those engines by some simple method? I will post a couple pictures tomorrow maybe you guys with knowing this info can help. I just wanted to say thanks again for your help because I am lost for sure. Take care and happy holidays |
12-02-2007, 01:16 PM | #5 | |
Take care |
12-02-2007, 06:09 PM | #6 |
Professional Grade
If you can get us pictures of the engine, we'll have a much easier time identifying it.
Could be an old GMC Toroflow diesel, a new 6.x, a Cummins, etc
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
12-02-2007, 06:16 PM | #7 |
Thank Guy I'll post some pic's tomorrow hopfully we can figure it out. Have a nice night.
12-03-2007, 02:29 PM | #8 |
hello again
Well I got a few pictures hope you all can tell what it is. from the vin numbers it appears to be a 74 but I still am not sure title say 73 go figure. Anyways the pictures are the best I can do, the right side of engine has so much stuff around it I cant get a good picture of that side. But the vin number is on the plate hopfully that will give you guys enough info. Take a look please! Take care and again thanks for the help on figuring this engine ID. |
12-03-2007, 03:10 PM | #9 |
Well, Whoop-dee-do!
It looks like an '82- '83 6.2 to me. The glow plug controller in the rear of the driver's side head in your one pic tells me this. Somewhere around '84- '85 they went to a totally different controller. '81s were painted red. Yours is also the HD non- egr version from a 3/4 ton or heavier truck.
The air cleaner base looks like it has been modified from a 6.9/ 7.3 Ford.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
12-03-2007, 04:43 PM | #10 | |
take care |
12-03-2007, 04:50 PM | #11 |
you know this truck is a odd cookie the other fellas have said that this truck didnt come with a diesel but the darn gauge cluster says use only diesel fuel. I guess that must have been changed too.
Heck I dont know this is driving me mad |
12-03-2007, 05:02 PM | #12 |
Well, Whoop-dee-do!
That's definitely an early '80s cluster. Looks like the guy that done the swap had both trucks parked side by side & swapped just about everything.
12-03-2007, 05:12 PM | #13 | |
Does the 82-83 6.2 take the same glow plugs or is there a change in design. Thanks |
12-03-2007, 05:18 PM | #14 |
Just wanted to say I have to sign off till monday, but any info help would be great, and thanks to anyone who adds more info cause I am jumpin in this thing with both feet and I cant see bottom........
Take care all, Ill look in Monday |
12-22-2007, 09:42 PM | #15 |
I think the round fuel filters are pre 84(date of change unknown)
Good chance there is a date on the back of the instrument cluster that is the same as the engine. Also if it has the starter on the wrong side for a Chevy(driver), it as an earlier 5.7 diesel which used the BOP tranny.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
12-23-2007, 06:26 AM | #16 | |
Take care |
12-24-2007, 08:45 AM | #17 |
Well it didn't have a diesel from the factory, the 5.7 olds diesel came out in '79 and was discontinued in '82(thank you arveetek for correcting me, i was a little off on the years there)
Jeffspower is right though, that cluster is from an early 80's truck because it has the 81-83 only wiper switch.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 12-31-2007 at 07:43 PM. |
12-28-2007, 07:09 AM | #18 |
Ultimate Diesel Dude
You definitely have a 6.2L diesel that someone has swapped in. The instrument panel has been swapped in as well. Any glow plug from a 5.7L, 6.2L, or 6.5L will work, but I would suggest you get AC Delco 60G glow plugs. Ask for those by name at the parts store.
The first factory diesel option came in 1979 with the 5.7L diesel, in 1/2 tons only. It was dropped in 1982 when the 6.2L was introduced in all truck lines. Visit www.thedieselpage.com for more info. It's devoted strictly to GM diesels. Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
12-28-2007, 07:24 AM | #19 |
Looks like your entire cab harness got changed out to a 78-83 harness. Reason I say is that would have to be the case to make that cluster work, but the wiper switch in the truck is 78-83 design and the wiring for them was totally different.
