Old 12-02-2007, 04:14 PM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
3:42 gears
what came with the 3:42 gears i am long for set. andi got a set of 3:73 just wonder if any one know what truck beside a big block that came 3:42s
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 12-02-2007, 04:41 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 3:42 gears
What axle, do you have? 10 bolt, 12 bolt, etc....
piecesparts is offline   Reply With Quote
Old 12-02-2007, 05:56 PM   #3
BowTieOgre
Re: 3:42 gears
I have seen several burbs in the 89-91 range that have the GU6 3.42 gears.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 12-02-2007, 06:14 PM   #4
piecesparts
Re: 3:42 gears
My 84 has a 12 bolt rear end out of a 78 chevy truck with the 3.42 gears and a posi. This rear end was installed after some gal hit the truck early in life and boggered it up on the curb. I changed out the gears for a set of 3.73 gears and gained some performance and did not really hurt my gas mileage in the deal. My son's 86 had a 3.08 geared 10 bolt open rear end, and I put a 12 bolt 3.73 rear end out of a 4 wheel drive truck and changed the axles to 5 bolt. This changed upped his gas mileage by 2.5 MPG. The 3.08 gears, 700 R4 tranny and Kansas hills did not match well.
Old 12-02-2007, 09:39 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 3:42 gears
I parted out a 77 model to get a drivetrain for my shortbed awhile back. It was a factory 350/ TH350, 3.42 truck.
Old 12-02-2007, 09:52 PM   #6
cjracing15
cjracing15's Avatar
Re: 3:42 gears
My 86 K-10 has 3.42s 10 bolt
cjracing15 is offline   Reply With Quote
Old 12-02-2007, 09:56 PM   #7
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: 3:42 gears
12 bolt truck rearend. my screams with 3:73 sounds like it comeing thru the hood at 55. much let higher mph. i have had 3 truck with 3:73 and they all been that way. i want 3:42 or 3:08. i am going to try them. i had a 80 camaro with 4:10 and my truck sound like it did the po told me it is 3:73
1967 Chevy stepside
Old 12-03-2007, 12:56 PM   #8
GM72K10
Next!
GM72K10's Avatar
Re: 3:42 gears
My 87 V20 P/u has 3:42s, 5.7L auto (originally 4M)
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 12-03-2007, 12:57 PM   #9
Pyrotechnic
Pyrotechnic's Avatar
Re: 3:42 gears
My 77 GMC Heavy Half came with a 350, Turbo 400, and a 3.42 12 bolt rear. This is a really good compromise between acceleration and highway RPM depending what tire size you have. 3000 RPM is around 65 MPH which is pretty acceptable. These were a really fun gear while I had them.
If you do primarily highway driving like me, as in 3-4+ trips at 75-80 MPH, you will want 3.08's but be warned, your acceleration will suffer quite a bit.
Pyrotechnic is offline   Reply With Quote
Old 12-03-2007, 02:27 PM   #10
tkeduk8r
tkeduk8r's Avatar
Re: 3:42 gears
I really like a 3.42 rear when I have trans that does not have an OD available, specially if you have a SM465 4 speed. A retired teacher buddy of mine had an 84 K20 with a 350, SM465, NP208, 3.42's and 245/75 16's, and we would pull anything we wanted, and still turn acceptable RPM's going down the highway at 65-70. THe taller tire helps too... If I end up going with a SM465 vs. my NV4500 in my 3/4 ton build I WILL find a 3.42 gear set for it...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 12-03-2007, 02:34 PM   #11
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: 3:42 gears
my 1977 longbed heavy half has 3.40, factory gears, says so on the build sheet, but it might be a 3.42, close enough to vary, and this truck is all original. She does whine up around 75, but she tops off way past the speedo.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 12-03-2007, 07:16 PM   #12
454HO
Re: 3:42 gears
My '77 12 bolt has 3.40 gears. This was from a 1/2 ton long bed with factory big block.
- Greg
454HO is offline   Reply With Quote
Old 12-03-2007, 08:08 PM   #13
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: 3:42 gears
My 86 C20 has 3.42 gears, but its in a 14 bolt sf rear.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-03-2007, 11:27 PM   #14
slugish
Slugish
Wink Re: 3:42 gears
have a 3 speed turbo 350 trans.
Had 3.73 gear , in my opinion , not very sreetable
went to a 3.08 , lot better on highway , but like to go to the strip sometimes
now I HAVE 3.42 . iTHINK THE BEST GEAR FOR A 3 SPEED THAT IS MOSTLY STREET DRIVEN , & OCCASIONALY THE STRIP .
slugish is offline   Reply With Quote
Old 12-05-2007, 09:32 AM   #15
86longbed
Re: 3:42 gears
I have 3.42 in my 86...they work fine
not to get off topic but when ya'll are saying streetable are we talking highway or just on the street because 3.73 gears with a 3 spd work just fine on the street and give you a good bit more pick up from a stop but on the highway is where the problems start anything higher than about 55 to 65 and the motor is wound up for any type of long distance traveling but the truck will go way past the speedo for short bursts
86longbed is offline   Reply With Quote
Old 12-05-2007, 05:05 PM   #16
piecesparts
Re: 3:42 gears
This whole discussion is about alignment of trannies and gears. I run 3.73 gears in my 84 GMC truck and my son has them in his 86 Chevy. Those rear ends are mated to 700 R4 trannies and th eoverdrive is a great combo with that gear ratio.
At the 75 MPH mark (no one runs 60 to 70 anymore) I am at 2700 RPMs and just starting to breath good on the engine. That also includes a smaller tire than most run on their trucks. I like the response of the 3.73 gears and the roadability of the cruise control and the response on the highways.
Old 12-05-2007, 05:31 PM   #17
jchav62
1962 C-10
jchav62's Avatar
Re: 3:42 gears
My 83 has 3.08's. They are great for that truck. My 62, which is a little more souped up, has 3.73's with a th350 and a GearVendors overdrive. With the overdrive, they are great! Without OD, not much for highway use.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 12-05-2007, 08:38 PM   #18
piecesparts
Re: 3:42 gears
My son's truck came with the 3.08 gears, but at that time it had a 350C tranny and that worked well for that truck setup. We then put in a 700 R4 and the mileage went out the bottom. The 3.73s gave that mileage back to us and the acceleration is great. Especially with the lower first gear in the 700 tranny.
Old 12-05-2007, 10:59 PM   #19
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: 3:42 gears
i got a 383 stroker. i got a bulit 350 tranny and 3:73 with a lock right locker. i love the truck for just short trips around town. out on the hwy it suck gas and screams bloody mary. i just want a 342 or 308 and try that i still want to play burn tires and go from 0-100 in a burst. just dont want it to scream to deaf on hwy
1967 Chevy stepside
Old 12-05-2007, 11:10 PM   #20
crossy
Oh,you can't buy that new
crossy's Avatar
Re: 3:42 gears
3.42 will only lower you about 250 RPM at any given RPM. I'm sure someone better at math than me can do the formula, but each step change is worth about 250 RPM, so i'm saying 3.08 would drop you 500 from where you are at now w/3.73's.
you cannot count on any certain truck to have a particular gear set you want. OPTIONAL gear ratios were availalbe in all years. 3.08's were not common though before 78.
my 74 has 3.40 stock(3.42) with the 3 speed manual tranny.
crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
