Old 12-02-2007, 05:14 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Body Mounts???
How much of a pain is it to install body mounts on a truck without taking the cab or front end off? Impossible???
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 12-02-2007, 05:43 PM   #2
woodridge
woodridge's Avatar
Re: Body Mounts???
Not at all, the only ones that may be tough are the front cab mounts, the bolts drop in from the top and some were welded. But with all the mounts loose, shift linkage and MC from the booster, you can jack the body high enough to replace them.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 12-03-2007, 07:18 AM   #3
mothertrucker424
mothertrucker424's Avatar
Re: Body Mounts???
on my truck i soaked the bolts with PB BLASTER then pulled back floor mat and cut weld on the interior bolts then i didn't unhook anything and just loosened the bolts on one side only and jacked it up behind the bolt that goes through cab and it came up high enough to pull out old and i replace them with poly ones (and it rides higher that factory i think but not bad looking) then tightened up that side and went to other and did the same i have a 72 4x4 k10 so it may be diffrent but same principle ideas
mothertrucker424 is offline   Reply With Quote
