Old 12-02-2007, 05:31 PM   #1
hiway
Mad Scientist
Standard gear ratio?
1984 Jimmy, 305 w/700r. What was the standard axle ratio in these?
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 12-03-2007, 11:07 AM   #2
Plumbnutz
Plumbnutz's Avatar
Re: Standard gear ratio?
RPO code on the sticker in glovebox should answer this, unless the axles have been re-geared or swapped. I can't remember where I saw this listings for the different codes.
74 K5 Blazer-built 350ci,Turbo 350, NP 205
8 lug Dana 44, GM Corp 14 bolt-4.56 gears, 37" Boggers
89 K5 Blazer-TBI 350, 700r4, NP 208
8 lug Dana 44, GM Corp 14 bolt-4.10 gears, 33" Toyo A/T
Plumbnutz is offline   Reply With Quote
Old 12-03-2007, 11:10 AM   #3
Plumbnutz
Plumbnutz's Avatar
Here's one
Chuck's Chevy Truck Pages
Old 12-03-2007, 03:07 PM   #4
hiway
Mad Scientist
Hey, thanks for the list! I've never heard of 3:21's and also noticed no 3:42's on there. I'm guessing I have 3:08's but not sure and not ready to pull the covers yet.
07 Suburban
02 Danger Ranger
Old 12-05-2007, 03:59 PM   #5
tobiahr
tobiahr's Avatar
you dont have to pull the cover. simply raise both rear wheels off the ground turn them one full rotation and watch how many times the driveshaft turns. that is the ratio. if you mark the tire and driveshaft with white chalk it makes it easier.
tobiahr is offline   Reply With Quote
