12-03-2007, 06:10 PM | #1 |
83 4x4 4spd
what is the most likely tranny and transfer case in a 83 2500 4x4 with 4 speed stick
12-03-2007, 06:48 PM | #2 |
EZEKIEL 25:17
Re: 83 4x4 4spd
The trans is a sm465 and I am guessing the t-case is a np205.
The np208 t- case was in the 1/2 ton trucks. The np205 is cast iron and the np208 is aluminium.
68 CHEVELLE(HORSESHOE) 69 LONGHORN 396 70 NOVA 454(FOR SALE) 71 SWB 307 71 EL CAMINO 383 72 GMC JIMMY 350 87 BLAZER 350 WIW? http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists. The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers... |
12-03-2007, 06:48 PM | #3 |
Re: 83 4x4 4spd
SM465 4 speed
NP208 transfer case
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
12-04-2007, 07:14 AM | #4 |
Re: 83 4x4 4spd
465/208
Tim |
12-04-2007, 01:38 PM | #5 |
Re: 83 4x4 4spd
sm465/np208
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-04-2007, 04:03 PM | #6 |
USMC
Re: 83 4x4 4spd
465-208 I own an 83 1/2 ton and this is what is in it. not bad though. Its not as strong as the 205 but it has a lower-low range gear then the 205.
2-1 in the 205 and 2.6 or 2.8-1 in the 208 (i dont remember)
Semper Fi |
12-04-2007, 06:03 PM | #7 |
Re: 83 4x4 4spd
the guy i bought it from said it has the higher gear ratio
12-05-2007, 07:14 PM | #8 |
Re: 83 4x4 4spd
The aluminum is a dead giveaway.......208
69' 3/4 4X4 470ci BBC 700 HP.... D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
12-06-2007, 03:35 PM | #9 |
Re: 83 4x4 4spd
heres my next question can i remove the tailstock of a 2wd transmission and attach the t-case to the tranny or are 4wd different than 2wd trannys
12-06-2007, 05:02 PM | #10 |
Re: 83 4x4 4spd
The output shafts in the trannys are different 4WD vs. 2WD.
Tim |
12-14-2007, 12:07 PM | #11 |
Re: 83 4x4 4spd
can they be changed to fit
12-15-2007, 01:53 AM | #12 |
Re: 83 4x4 4spd
Tim |
01-06-2008, 07:49 PM | #13 |
Re: 83 4x4 4spd
Pics always help me. This is a good explanation.
http://www.novak-adapt.com/knowledge/sm465.htm
68 4x4, 454, 4 speed, disk brakes both ends, Sold my 69 SS396 Elcamino when young & stupid |
01-07-2008, 05:31 AM | #14 |
Re: 83 4x4 4spd
I don`t know what trans you want,but get a 4wd version or a complete t-case/trans combo if you`re changing t-cases,too.
