12-03-2007, 07:04 PM | #1 |
Active Member
How to design Watts Link
Hi! Im planning on building a watts link for the back of my truck.. Just curious if anyone has built one, or knows of a formula to determine how long the links/center bar need to be to accomidate a certain amount of lift? any help is greatly appreciated!!-Mark
zmtgoat@hotmail.com |
12-03-2007, 07:36 PM | #2 |
Rust Buster
Re: How to design Watts Link
Check with John, aka ChiefRocka or Kevin, aka Rokcrln. They have been building/designing a killer 14 bolt. Thread is at the bottom of the front page. Good Luck - Jerry
12-03-2007, 11:49 PM | #3 |
60-66 Nut
I can't help with the watts link, but I just had to say nice job on the fab work you've done.
Got any more pics?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 12-03-2007 at 11:49 PM. |
12-04-2007, 10:43 AM | #4 | |
Hollister, CA.
There is no set formula for the Watts.... The pivot has to be in the DIRECT center of the axle...Normally I use a pivot that is on 6" centers. With the rear-end centered and set at ride-height (bags at half their travel) and the center pivot vertical , measeure and fab up your links from there...equal length to your chassis. Looks like the lower link bar mount will be easy off the rear frame rail that looks almost vertical. Cool bag mounts !! Good job...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 12-04-2007 at 10:46 AM. |
12-04-2007, 11:49 AM | #5 |
Active Member
Cool!! I plan on having about a 4" ride height and i setup the back rails behind the axle for the watts mount.. Thanks!! your input is greatly appreciated!!
-Mark http://s100.photobucket.com/albums/m37/McIvermark/66/ http://s100.photobucket.com/albums/m...ermark/66/cab/ http://s100.photobucket.com/albums/m.../engine%20bay/ http://s100.photobucket.com/albums/m...%20suspesnion/ http://s100.photobucket.com/albums/m...%20suspension/ Last edited by MacSic66; 12-04-2007 at 11:51 AM. |
12-04-2007, 11:57 AM | #6 |
Active Member
12-04-2007, 12:49 PM | #7 |
Sweet! I set my truck for the same ride height, it looks good, still has pleanty of travel, and can lay all the way out.
12-04-2007, 05:56 PM | #8 |
What size tires are you running up front?
12-04-2007, 06:06 PM | #9 |
Active Member
hey.. i plan on running a 28-29" tall front tire.. what are you running on yours?
No vehicle is "too nice" or "too straight" to cut up. |
12-04-2007, 07:53 PM | #10 |
Dino were did you go? He is doing a wats link because he is running stock style trailing arms that have been relocated for a sever drop. Dino check out his Photo links. He did a very nice job.
Kevin LFD Inc. Last edited by Rokcrln; 12-04-2007 at 07:53 PM. |
12-04-2007, 07:56 PM | #11 | |
Kevin LFD inc. Last edited by Rokcrln; 12-04-2007 at 07:56 PM. |
12-04-2007, 08:43 PM | #12 |
Active Member
thanks!.. the front tubs clear a 29" tall tire, the firewall tubbing will allow for really low minimal turning, the back is setup for a 30" tall tire, ive got to get work done on the burban!! then on to the watts and bedfloor, rear tubs, finish the gastank, get a tailgate exc.. then off to the blasters, reassemble, swing hood, bearclaw latch the hood, swing doors, bearclaw the doors, rust repair, door handles... the list goes on and on...!!!!
-Mark thanks for the positive feedback guys!!!!!
12-04-2007, 09:17 PM | #13 |
Well at least you have started yours and have a plan. Right now my plan is to finish everyone elses projects then rol mine out of the storage side of the shop and start it It will be a month or two before it gets touched but I am planning out the full build and starting to collect the needed parts so I will be ready when that day comes.
I am planning on the bear claws as well for doors and the tail gate. Have not thought about the hood but it would be nice having it just "CLICK" like every thing else. Kevin LFD Inc. |
12-04-2007, 09:23 PM | #14 |
Active Member
yeh the hood latch should be cool! click.. i plann on hooking it up to a pull cable inside the cab, probably use a bicycle brake cable, then gas shocks to lift it,the stock hood springs are long gone..
-Mark
12-04-2007, 10:14 PM | #15 |
you got some nice work there dude
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
12-04-2007, 10:46 PM | #16 | |
Kevin LFD Inc. |
12-04-2007, 10:53 PM | #17 |
Active Member
thanks!! ur truck is coming along good!!! sweeet!!! same idea on the inner fenders!!
12-05-2007, 01:22 PM | #18 |
MacSic66, your truck is looking good. I like the rear setup. What are those hood hinges from?
12-05-2007, 02:06 PM | #19 |
454 club
Nice work,
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
12-05-2007, 05:25 PM | #20 |
Active Member
the hood hinges are off of a 58' chevy truck, 57' and earlier would work too, the 58 has the extra support tab on it..
12-06-2007, 03:40 PM | #21 |
Looks good..
98 LS1.. Word of advice before you do the exhaust. Toss those manifolds and pick up a set of Edelbrocks 1 3/4" stepped 1 7/8 long tube headers with high velocity merge collectors for the 98-02 F-bodies. Here they are on summit and not all that much http://store.summitracing.com/partde...5&autoview=sku Here is what they look like in my 63 truck with a summit 3" x-pipe. With the heads cam package through a 4L80E it makes 428rwhp. http://73-ls1.com/63truck/1-18-06/engine_bay_02.jpg http://73-ls1.com/63truck/1-18-06/engine_bay_03.jpg http://73-ls1.com/63truck/1-18-06/exhaust_01.jpg http://73-ls1.com/63truck/1-18-06/exhaust_02.jpg http://73-ls1.com/63truck/1-18-06/exhaust_03.jpg http://73-ls1.com/63truck/1-18-06/exhaust_04.jpg http://73-ls1.com/63truck/1-18-06/exhaust_05.jpg This is what I did for motor mounts. There is a poly bushin the there.. http://73-ls1.com/63truck/motor_moun...or_mount_2.jpg http://73-ls1.com/63truck/motor_moun...otor_mount.jpg http://73-ls1.com/63truck/motor_moun...t_of_motor.jpg One other thing. I am running a truck pan on mine and planing on switching over to an F-body pan as it won't hang down as low. Looks like you have a F-bod motor so your probably ok. Last edited by Super73; 12-06-2007 at 03:52 PM. |
12-06-2007, 08:49 PM | #22 | |
Active Member
what wiring harness are you going with? i scored a pair of pacesetter headers, direct replacement for the camaros for cheap on e-bay, i have to run shorties on it.. i plan on doing a 2 1/2" exhaust with an x pipe.. i went with these motor mounts http://carshop.carshopinc.com/produc..._id/86960/2350 http://i100.photobucket.com/albums/m...y/IMG_1039.jpg http://i100.photobucket.com/albums/m...y/IMG_1038.jpg
12-06-2007, 09:18 PM | #23 |
Active Member
12-06-2007, 11:08 PM | #24 |
I've been laggin", a 28" tall tire.
12-07-2007, 01:27 AM | #25 |
If your going with shorties, you might want to try C5 Z06 manifolds. They flow better than any shorty out there do to the Try-Y set up. They can be had for about $100.
I would advise going 3" X-pipe from the get go. I've been tuning LS1's since 2001 and can tell you I have never seen a reduction in power on them going with bigger exhuast. My exhaust is extreamly free flowing, but when I uncorke the warlock mufflers I still pick up 7rwhp and 10-15 ftlbs of TQ down bottom. I am running a factory F-body PCM and harness. I am also running a 4L80E which I would do over a 400/GV unit. There are a couple small things you need to do like swap a couple wires around at the trans connector and have HPtuners load the trans controllers on the PCM. They charge $50 for that. But doing that allows you to run a lock up conveter and set all your shift points extreamly easily. Last edited by Super73; 12-07-2007 at 01:31 AM. |
