Old 12-03-2007, 07:26 PM   #1
chevy72blu
chevy72blu's Avatar
How important is priming the oil pump?
Because my BBC is installed so far back, It would be impossible to remove the dizzy completely and prime the oil pump. I assembled the motor over a year ago with a high grade assembly lube on everything. Could I not just splash some oil on top of the heads, and crank the motor w/o ignition to allow the oil pump to do the work on its own before firing it? I'd really rather not have to pull the motor - but I will if I need to.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 12-03-2007, 07:37 PM   #2
airdale94
airdale94's Avatar
Re: How important is priming the oil pump?
That's the whole purpose of assembly lube is to provide lubrication on initial startup. I personally wouldn't worry about it. I've rebuilt several engines and have never primed the oil pump. All you are really doing by priming the oil pump is shooting some oil up to the rocker arms. The crank and rod bearings shuld have assy. lube on them anyway. As with cam bearings, lobes, and cylinder walls. The only pumps that actually need to be primed are external dry sump and you pack those with petroleum jelly to prime them.
I would just double check your intial timing, prime the carb. and fire it up.
airdale94 is offline   Reply With Quote
Old 12-03-2007, 07:37 PM   #3
oldspowered67C10
I think that would be sufficient.
oldspowered67C10 is offline   Reply With Quote
Old 12-03-2007, 07:47 PM   #4
jim zag
ENGINE BUILDER
jim zag's Avatar
If you can not remove the distributor and use a oil pump priming tool and a drill then fill the oil filter and oil pan, remove the spark plugs, and spin the engine over until you get oil pressure.
JIM ZAG
jim zag is offline   Reply With Quote
Old 12-03-2007, 07:58 PM   #5
chevy72blu
chevy72blu's Avatar
Good, thanks for the info guys. I appreciate it.
How does one check initial timing without the motor running? Im still hoping and praying that I stabbed the dizzy in the right location.
RIP EastSideLowLife
Old 12-03-2007, 08:29 PM   #6
BCOWANWHEELS
i dont see why you cant pull the dist. ?
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 12-04-2007, 01:13 PM   #7
chevy72blu
chevy72blu's Avatar
Because I installed the motor as far back as possible for weight transfer and the lip of the firewall is above the distributor.
RIP EastSideLowLife
Old 12-04-2007, 04:06 PM   #8
crazy longhorn
Fabricate till you "puke"
Remove the cap & rotor.....you should be able to pull the dist.
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-04-2007, 04:22 PM   #9
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Chances are that you did not "stab" the dizzy in the correct location to begin with unless you were EXTREMELY careful, were at true TDC on #1, had the dizzy body correctly positioned and had the rotor positioned on #1 (after it rotates 15 degrees when the gear engages the cam). Good Luck.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 12-04-2007, 04:28 PM   #10
Wrenchbender Ret
I have an old fire extinguisher I put a tire valve in the side & a hose on the outlet. I fill it with oil & pressurise it. I hook the hose into the opening for the oil sender unit & squeeze the handle putting pressure to the oil gallery.
I think you can get by with filling the filter up with oil & cranking the engine with the plugs out or ign disconnected.
Wrenchbender Ret is offline   Reply With Quote
Old 12-04-2007, 07:46 PM   #11
67_C-30
I have a radical idea!
67_C-30's Avatar
If you can't prime the oil pump, I'd take out the plugs and take off the coil wire and and free spin a little with the starter before actually cranking it. It would allow the oiling system to prime without having any of the stress of compression.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 12-04-2007, 10:36 PM   #12
Billla
Billla's Avatar
IMHO, I wouldn't fire anything that's been sitting without pre-oiling. I agree that if all you can do is pull the plugs and turn it over, I would STILL do that vs. nothing at all.
Easy check on the distributor - if you're at TDC compression #1 the rotor should be pointing directly at the #1 spark plug tower You're generally looking for around 12 BTDC for initial startup.
Billla is offline   Reply With Quote
Old 12-04-2007, 10:51 PM   #13
496stroker1
had a cam go flat on me with my first big block chevy bout 5 years ago, probably cause the engine spun over too much before it started. if space is tight how about using a right angle air drill with an oil pump primer
496stroker1 is offline   Reply With Quote
