Old 12-03-2007, 11:03 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Rear shackle bushings
I am trying to find some rear spring shackle bushings for my 72 K5 (the ones that go between the shackle and the frame). I was hoping to walk into one of the local parts stores and pick them up, but so far no luck. Does anyone know a part number from one of these places. When I ask the counter guys, they just look at me and say "Uhh...sorry, the computer only goes back to 1973". My next resort would be ordering them online, but in the interest of time I was hoping to pick them up locally.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-04-2007, 07:42 AM   #2
jaros44sr
jaros44sr's Avatar
Re: Rear shackle bushings
www.prothane.com. just looked at the catalog, seems there are two sizes, 1 3/8" and 1 1/2". It's on pages 29-32. If your looking for rubber mounts, I haven't seen any sites
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-04-2007, 05:55 PM   #3
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Replaced my shackle bushings on my 70 Blazer and they are 1 1/2" which are the same as my 86 Chevy is. Went with Energy Suspension urethane bushings. You can get them by themselves or as a kit that includes spring bushings.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 12-04-2007, 06:05 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
Thanks guys. I was kinda hoping to go with a factory style rubber bushing for this. I have urethane upfront where there is a lot of oil, but thought the rubber might be nice in the back for a slightly better ride, maybe not. Plus I am tired of ordering things and waiting on them. Is there anyway of telling if it is the 1 3/8 or 1 1/2? I can't see much with it installed and was hoping to have all the parts collected before I tore it down. Maybe it if is the 1 1/2 I can go into the store and say I need on for a 1985 K10? Thanks again.
Old 12-04-2007, 07:22 PM   #5
EFI70Blazer
Active Member
Just remember that you will probably need a torch to remove your old ones. I used a small propane torch to burn most of the rubber bushing out and then used a hack saw to cut the metal sleeve so that i could pound it out since i dont have a cutting setup. If you want rubber ones they should be the same as 73-87 as long as you get 1 1/2 inch bushings.
Mike T.
Oregon
70 GMC Jimmy 4x4
Old 12-13-2007, 07:38 PM   #6
blazer74
If you still need shackle bushing you can order the whole shackle and bushing assy for gmpartsdirect.com, their like 12.00 each. Just get the p/n from a chevy dealer.
blazer74 is offline   Reply With Quote
Old 12-23-2007, 09:08 AM   #7
Critter
Future TOTM Winner
Critter's Avatar
Does any body know a GM part number for the entire shackle assembly? I can't get any of the punks around here to look up a part# for me (they give up after 30 seconds when the computer doesn't automatically spit out a #). After studing my original shackles, they look pretty worn out, I might as well replace them now especially if they come with bushings. Thanks guys.
Old 12-23-2007, 04:01 PM   #8
Jtrux
I'm a poor spectator
Jtrux's Avatar
I can't believe you still haven't ordered somthing yet, i'm pretty disappointed in you.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-24-2007, 11:29 AM   #9
Critter
Future TOTM Winner
Critter's Avatar
Remind me again why I put up with you!
Have you welded up your exhaust yet???
