Can someone tell me what's involved in switching my 3 speed to a 4 speed? My questions are: Will a 4-speed (saginaw) go right in as same as the 3-speed, will the same bellhousing work, will the drive shaft need to be re-done, so on... I have a 71 Chevy long bed, 350 3 speed on the floor I think its a Saginaw. Used to be on the column. I used it mostly for driving to work and a little fun, not really racing. Any help? I see a few 4 speed Saginaw on E-Bay for sale... $200 to $500
TJ Last edited by tjvending; 12-04-2007 at 09:15 AM. |
Fabricate till you "puke"
Re: converting a 3 spped to 4 speed? 71 chevy
You need to swap the input bearing retainer from the 3 spd, to the 4 spd(saginaw), & will use a bolt & nut on the bottom 2 ears on the trans to bell. Otherwise its a bolt in fit.
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Any Shifter problems, and what should I use?
TJ |
You will need a good 4 spd shifter.....Hurst is my choice. For your app , a hurst superspeedway, or Indy (a little cheaper) should do the trick. Best of luck,
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 12-04-2007 at 03:58 PM. Reason: shift handle |
You`ll want a bench seat shifter,puts it forward a bit.
Is the input bearing retainer om the front shaft? Do you have a picture? Is this easy to do? TJ
Its the pc that the throwout bearing slides on....4 bolts remove it from the front of the trans. You need to replace the gasket & an inner seal while you are in there, & it would be good insurance to replace the front bearing on the trans at this time. best of luck,
Did it in our 68,went from 3 on the tree to the muncie m-21, no issues. Had to fab a trans support though. The 3-spd just hung there in space, didnt like the looks of the m-21 just hanging there. No biggie..works great. Hurst pro-comp shifter...
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
![]() Join Date: Oct 2006
I did the same thing on a Nova and didnt have to change the bearing retainer.
I'm confused now,cause I too am going to be doing this for a friend tomorrow. Thanks -Lance BTW I am doing it on a '69. saginaw 3spd for saginaw 4spd
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Official Site Guitar Shredder
will this swap work on 67s?? i have a thread with some questions........? i also have a 4speed saginaw.....but i have the smaller 67 3speed trans............thanks again tony
#11 | |
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 12-06-2007 at 10:11 AM. Reason: spelling...lol |
Did you do the job on the 3 sp to 4 sp> How did it go, let me know? TJ
#13 |
Did you do the change over on the 3sp to 4sp, let me low? TJ
#14 |
ttt?????
#15 |
#16 | |
#17 |
Re: converting a 3 speed to 4 speed? 71 chevy
Havent done it yet. My friend is waiting for the shifter to come in. Then I will be pulling it out and I'll take some pics and post 'em.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT Last edited by manimal; 12-12-2007 at 09:24 AM. |
